Old 03-07-2008, 04:51 AM   #1
ainokea
drop spindle shaft
i have a 3" drop spindle from belltech.....
the problem is the spindle shaft is 1/2" shorter than my stock ones.
can the spindle shaft be press out and use my old shaft??
ainokea is offline   Reply With Quote
Old 03-07-2008, 06:08 AM   #2
benoit454
Chris
benoit454's Avatar
Re: drop spindle shaft
maybe you got the thick 1.25 rotors on a 1 inch spindle, that's all I can think of. I don't think you can do anything with it except exchange the spindles for the thick 1.25 rotors or buy new 1 inch rotors and calipers.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-07-2008, 07:21 AM   #3
ainokea
yup i got the wrong one.....
shipping it back cost $$$$ so i will just buy another set.
Old 03-07-2008, 08:23 AM   #4
benoit454
Chris
benoit454's Avatar
another set of drop spindles? that costs even more!!!!!!!!!
I'd try and buy the brakes to fit and use em, be alot cheaper then new spindles.
Chris
GIT R DONE!!!!!!
Old 03-07-2008, 09:39 AM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
I did the same thing so I bought new rotors, good thing is you'll have new brakes you might also have to get the smaller calpier to, and on the spindles you'll have to grind the calpier ears a little, thats why my truck has been on jack stands for over a week
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-07-2008, 06:31 PM   #6
beaterC10
The rotors, calipers, and bearings are different between 1 and 1.25 spindles
beaterC10 is offline   Reply With Quote
Old 03-08-2008, 02:12 AM   #7
ainokea
did anybody swap rotors before?. can i use my calipers & pads?
both rotors is cheaper than buying another spindles....
Old 03-08-2008, 02:25 AM   #8
beaterC10
Did that on my 86. You have to change the rotors, calipers, and bearings.
Old 03-08-2008, 06:29 AM   #9
benoit454
Chris
benoit454's Avatar
That's still cheaper then spindles, but shipping them back would be the cheapest I think
rotors are about 25 each, bearings like 20-40 for both sides and seals, they are like 5 bucks each I think. and calipers are cheap too about 20 each I think. I just done that job last year on the 84 rotors, bearings, seals pads and calipers.
Chris
GIT R DONE!!!!!!
Old 02-26-2010, 11:23 PM   #10
love my 72
love my 72's Avatar
Man i have the same problem!!!!!! Except i cant return the spindles since i bought them at a swap meet. A buddy of mine has a 20,000 pound press i could use. and since my rotors, calipers and pads are fairly new im considering swapping the shafts.
Has any else done this before or had it done? any input on how to go about pressing out and pressing in the shafts is appreciated.
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 03-19-2010, 04:00 AM   #11
love my 72
love my 72's Avatar
You wouldn't happen to have a picture of the area that needs to be ground down would you?
I'm in the proses of putting together the front brakes for my 1" rotor spindles
65 **stang 6cyl
99 Tahoe 2DR, 2WD
Old 03-19-2010, 03:55 PM   #12
flamingbig10
6.0 powered square
I took and little off the spindle ears were the caliper bolts on
Aaron
