Old 03-07-2008, 06:32 AM   #1
into69z
"brand new second-hand"
into69z's Avatar
tilt column out of a 71 Blazer-gray wire?
I just bought a tilt column out of a 71 maybe a 72 Blazer today at my local pick-a-part. I almost passed out when I made the find. The Blazer still had the bucket seats, a perfect grill and the tilt. I bought the tilt and let another have the grill cause I got a 69 and left the seats cause they wanted $40.00 each and they would have needed to be re-done-anyways, I have a single gray wire that connects to the fuse box-what does this wire do? and which hole on the fuse block does it go in?....thanks
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 03-07-2008, 07:32 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: tilt column out of a 71 Blazer-gray wire?
usually gray wires in the column area are for illumination. possibly for the shift indicator.
68C15 is offline   Reply With Quote
Old 03-07-2008, 07:45 AM   #3
wibilly
wibilly's Avatar
i agreeshift indicator light there should be a terminalon i belive upper right of fuse panel labeled cluster lights or somthing like that. it's beenalmost a year since i was up under the dash you'll see itif you look under there
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-07-2008, 08:21 AM   #4
into69z
into69z's Avatar
thanks for the help.....steve
Steve
67 Camaro
96 Impala ss-sold
b69:
