Old 03-07-2008, 05:30 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Siezed engine problem
I have a Jimmy with a siezed engine. I'm working on it's replacement right now, but then realized my problem. How to I get the torque converter bolts out to remove the tranny on an engine I can't rotate? I didn't want to pull the tranny and transfer case with it, just wanted to swap the motors, but that may not be possible. Will the tranny pull back far enough to reach them? Can I turn the transmission enough to get the torque converter off the tranny, then take it off the flywheel? Any ideas will help at this point.
hgs_notes is offline   Reply With Quote
Old 03-07-2008, 05:39 PM   #2
69rut
Re: Siezed engine problem
Sing along now, the crankshaft is connected to the flexplate, the flexplate is connected to the torque converter, the torque converter is connected to the input shaft.........
Unbolt the transmission from the engine and seperate. The torque converter will remain on the flexplate. Any oil in the converter will come out with the input shaft, so be careful not to take a bath.
trailers are for boats
69rut is offline   Reply With Quote
Old 03-07-2008, 06:01 PM   #3
greasy68
greasy68's Avatar
It may be better to just pull the engine tranny out together and unbolt the tranny then pull it off the TC. Like 69rut said, the converter will stay with the flywheel but you will have access to the rest of the bolts. BTW, how did the engine sieze?
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 03-07-2008, 06:58 PM   #4
cdowns
cdowns's Avatar
pull engine and if its seized that you cant turn it just take the pan off and pull the crank out with flexplate and converter attached then you'll be able to get to all the bolts on the converter
Old 03-07-2008, 07:06 PM   #5
arkracing
Weekend Warrior
Will the motor turn @ all??? or is it solid? If you can get it to turn try turning it as far one way as possible, and then back the other way. Sometimes when a rod breaks and jams somewhere you can do the opposite rotation thing and get enough rotation to get the bolts. If the motor is just seized up solid then:
Probably have to pull the converter with the motor. Be sure to have a couple buckets under it and lots of old towels and speedy dry handy. This is a great way to make a mess of your shop floor.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-07-2008, 09:52 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
If you take the transmission housing bolts out and pull the engine you shouldn't have any problem getting the torque converter bolts out...
LockDoc
Leon
Old 03-07-2008, 10:21 PM   #7
slug
slug's Avatar
if you pull the converter with the engine you may be able to take the convertor off with a wrench after it is out
slug is offline   Reply With Quote
Old 03-07-2008, 10:34 PM   #8
cdowns
cdowns's Avatar
LockDoc
i wonder what type of converters you've been woring on the ones ive seen require turning engine over to access ALL the bolts
Old 03-07-2008, 10:41 PM   #9
Longhorn321
Size Matters
Longhorn321's Avatar
How 'bout dropping the pan and unbolting the rods? If the main bearings are seized, then you could loosen the main caps and turn the engine. I am not speaking from experience cuz I have never taken the pan off in my truck so I don't know how hard that is, but I assume it is possible to do with the engine jacked up a little? Just curious, is it a 6 or 8 cylinder?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 03-07-2008, 10:45 PM   #10
fine69
fine69's Avatar
Just pull the engine with the converter still attached to the flywheel. Best way. Been there, done that.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-08-2008, 02:01 AM   #11
LockDoc
LockDoc's Avatar
Sorry, brain fart.... I'm thinking pressure plate. That's why I don't post much. It's too easy for me to open mouth & insert foot....
LockDoc
Leon
Old 03-08-2008, 06:02 AM   #12
hgs_notes
GEARHEAD
hgs_notes's Avatar
I bought the Jimmy from a junkyard with siezed engine. Its a 400 sbc and after pulling the heads, I figure it had a cracked block, then sat and rusted solid. It no movey no more.
BTW, thanks everyone for the help. I wasn't sure the tranny would pull away enough or if the torque converter would turn enough to come away from the tranny input shaft.
Longhorn 321, if you pull the pan on a siezed motor, you can loosen all the bolts, but if the pistons wont slide up the cylinder, the crank will not drop out. Because the rods are coming in at opposing angles, it will still be stuck, unless of course you use a torch to cut the rods. At that point, why bother.
Old 03-08-2008, 08:16 AM   #13
arkracing
Weekend Warrior
Holy crap that's pretty bad, looks like a saltwater boat motor - well it's an anchor now. I've never seen a 400 with pistons that didn't have valve reliefs. Do the bores measure to 400 specs? 4.125" or larger?
just yank the converter still attached to the flexplate. - Be ready with the towels & speedydry
-'66 C10 Suburban
Old 03-08-2008, 09:29 AM   #14
Longhorn321
Size Matters
Longhorn 321, if you pull the pan on a siezed motor, you can loosen all the bolts, but if the pistons wont slide up the cylinder, the crank will not drop out. Because the rods are coming in at opposing angles, it will still be syuck, unless of course you use a torch to cut the rods. At that point, why bother.
Yeah, your probably right, that thing is pretty well done.
...WOOOO HOOOO!!!!
Old 03-08-2008, 09:42 AM   #15
89 crew
Don't forget to change the front seal in the transmission when you have the engine and converter out. Been there made that mistake before!
89 crew is offline   Reply With Quote
