Engine n00b
Someone explain backspacing and wheel selection better to me...
Im far more used to offsets and imports...
Looking at these: http://www.jegs.com/p/Wheel+Vintique...10002/-1/36674 For my 1970 C10, which will have the ECE 2/4 premium drop kit on it. Plans are to eventually go disc brakes, but right now its drums all around. Thinking 15x7 up front and 15x8 in the rears... Is the 4" backspacing enough? |
Engine n00b
Re: Someone explain backspacing and wheel selection better to me...
Oh, and explain to a n00b what size tires you would pick on those, too
Restoration Virgin!
Hey,
goto this FAQ thread.... think it'll explain backspacing to you... http://67-72chevytrucks.com/vboard/s...d.php?t=145290 Have fun!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Engine n00b
That does explain it well, but what it doesnt answer that I still need to know... is 4" backspacing (aka 0 offset) enough for my 70 c10?
#5 | |
Will 4"BS work? Yes. So will 3", 3.5", 4.5", 5" . . .... It depends on what you like & how low you get. Give us a starting point of reference. Post a pic of what you have now & what your current BS is so we can figure from there.
#6 | |
Engine n00b
Thats the rub. No idea. I have yet to even remove a wheel from it! |
Gotta start somewhere. 8" wheels w/4" BS work on these trucks. Since each suspension set-up (and truck) is slightly different, it's best to have a starting point (control) before making recommendations.
#8 | |
Engine n00b
