Old 03-07-2008, 09:19 PM   #1
shelby987
shelby987's Avatar
2wheel or 4 wheel alignments?
I will be buying my first set of 'new shoes' for my first 4x4 this weekend, and at almost $900 all told, I would like them to last as long as possible.....for a truck (in particular a 4wd) is a 4wheel alignment required, or is a 2wheel all I really need?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 03-08-2008, 03:43 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 2wheel or 4 wheel alignments?
I've been told there isn't really anything that can be done to adjust the rear axle so not to worry about it. I haven't had either of my trucks aligned and they seem to track real well and I don't see any alignment wear issues.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-08-2008, 05:15 AM   #3
Eichorst69
The only thing you can adjust on an old
4x4 is the toe on the front end.
Rob
Eichorst69 is offline   Reply With Quote
Old 03-08-2008, 06:26 AM   #4
Blue_71
Bloo
Blue_71's Avatar
you can actually adjust camber also, but it takes a special sleeve and socket, and lots of time. usually though, camber will not be out unless something is worn out anyway
there is nothing you can do at all on the rear. 4-wheel alignment only applies to IRS and FWD ussually
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-08-2008, 09:03 AM   #5
wibilly
wibilly's Avatar
i didn't know there was such a thing as a 2 wheel alignment. what do they line them up with? i would not bother to spend the money on anything but a 5 wheel alignment
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-08-2008, 09:12 AM   #6
jrdv
jrdv's Avatar
Not trying to hijack the thread, but the question does apply to this topic.
Does anyone align their own frontends? JC Whitney sells a tool that looks like a large yardstick. Has anyone used it?
john
jrdv is offline   Reply With Quote
Old 03-08-2008, 11:10 AM   #7
Blue_71
Bloo
Blue_71's Avatar
2 wheel alignment is basicly the same thing-- you still have to hook up all 4 sensors, but the alignment machine doesnt show any measurements for the rear. the alignment machine we have at work decides automatically if the vehicle can be aligned in the rear, and decides weither or not to show the specs. for example, on chevy trucks, the specs will be greyed out and not accesable for the rear, and say a 2000 oldsmobile alero, will have the specs accesable for the rear to be adjusted
1989 Chevy K2500
Old 03-08-2008, 11:48 PM   #8
1969K10
1969K10's Avatar
john
never bought the tool from JCW, but I use my tape measure. pick identical points on front & rear of tires and measure between them. You want the front tires about 1/8" narrower that the rear. when you go down the road, the front pushes out, and will be "straight".
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
