Old 03-08-2008, 06:46 AM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
94 350 into a 69
i got a 94 van and want to put the motor in the 69.will my intake fit the 94 motor. and is there anything else i need to change to put this newer 350 in the 69
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 03-08-2008, 07:03 AM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: 94 350 into a 69
Your 69 intake will not fit the 94 motor. The heads are different. You can get a new Edelbrock intake that will fit those heads and then you will be good to go.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 03-08-2008, 07:12 AM   #3
68jimmy
68jimmy's Avatar
I have a 350 from an 88 Z-28 in mine w/ the roller cam and centerbolt valve covers... The blocks are basically the same so as long as you have the correct motor mounts, accessory brackets and such it should go fairly smooth. Are you going to use a carb or efi?
donovan
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 03-08-2008, 07:19 AM   #4
Boog
laying low
Boog's Avatar
You can buy an Edelbrock intake to fit the 94 heads or elongate the two center bolt holes on your stock intake on each side as the 94's two center bolts stand up rather than angle like the others. Not a big deal to elongate them.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-08-2008, 07:23 AM   #5
72shadetree
KEEP ON TRUCKING
useing a carb
thought about the tbi but dont know enough about the wiring and i done a search and found out the wiring is alot harder for the 94. 93 and back was easier the way i understand
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 03-08-2008, 09:17 AM   #6
68jimmy
68jimmy's Avatar
I had previously used a factory aluminum two plane manifold in which I just opened up the two middle holes. Worked good until I had some cash to get a performer manifold. I'm also using an hei that I got off ebay a few years back.
