Old 03-08-2008, 10:48 AM   #1
rotgg
guys with 4" Z what did you do for shocks
what did yall use for shocks with a 4 inch z on a 87 i am having trouble finding a shock that will fit with enough travel
rotgg is offline   Reply With Quote
Old 03-10-2008, 10:35 PM   #2
dinotruck68
dinotruck68's Avatar
Re: guys with 4" Z what did you do for shocks
Rancho has sum prett godd shocks thats what i used.. Rancho rs5000's or 9000's for even more travel
dinotruck68 is offline   Reply With Quote
Old 03-10-2008, 11:42 PM   #3
rotgg
that was my problem trying to find something that would fit but has large travel
Old 03-11-2008, 03:55 AM   #4
royo
royo's Avatar
How bout some pics of 4in z
nickle and dime
royo is offline   Reply With Quote
Old 03-11-2008, 06:51 AM   #5
rotgg
i am going to post a build thread when i am done i did the z in the front and a triangulated four link in back swapped motor to a lt1 should be close to finished this month i did find a cst shock that has a 10.5" collapsed and 18" extended which is 7.5" of travel and i think that will do it with out limiting my lift
Old 03-11-2008, 03:35 PM   #6
HotRodYJ
HotRodYJ's Avatar
Z-ing reallly has no effect on shock selection, it's more what else you've done, bags, A-arms, spindles that will answer that question. I moved my crossmember 5" instead of Z-ing, but same effect as a 5" Z. Running factory spindles and bags on factory arms. I bought factory shocks and moved the upper shock mount to compensate for the crossmember moving. The shock still has more travel than I can use for my set-up.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 03-11-2008, 10:38 PM   #7
rotgg
how many trucks have you Zed
Old 03-11-2008, 11:53 PM   #8
HotRodYJ
HotRodYJ's Avatar
Explain to me why it would be any different? Assuming you move the upper shock mounting hole along with the Z like everyone else does, the relationship from upper mount in the frame to the lower mount on the lower A-arm doesn't change at all from stock. It's the other modifications to the suspension that cause you to use a different shock. air bags, lower springs, different control arms. These things are what change that shock mounting relationship.
My crossmember is 5" higher up in the frame than it was stock. Take a wild guess how far my upper shock mount had to be relocated... 5" exactly the same amount. My only mod to the suspesnion itself is changing it's location in the frame and airbags. Zing the frame does exactly the same thing. If the front suspension was totally stock and your only mod was to Z the frame, a stock shock will still work exactly like it did without a Z because the suspension itself hasn't changed, only it's relationshiop to the rest of the frame has and the shock mount moves with the Z so that relationship is unchanged.
Old 03-12-2008, 01:58 AM   #9
rotgg
i am guessing that means 0
ok i will explain
yes you move everything up 4" right behind where the stock shock goes so guess what that means if it is stock you need to move the shock mount up 4" there is only one problem with that when you Zed the frame up 4" now the shock mount is very close to the cab and the steering column and if the truck was stock that would be fine but i need a shock with 10" of travel and fit in that space
so because of the Z you are very limited on what length of shock you can run so you can see how Zing the frame has a huge effect on shock selection
Old 03-12-2008, 02:45 AM   #10
Slmd92DIME
Slmd92DIME's Avatar
You need a shock with 10" of travel??? I have contitech 2600s and a 3 inch drop spindle. I have done a 4 inch Z on my 65 it will have stock shocks with maybe the lower tabs cut off and replaced with a stud welded on instead.
If that doesnt help unbolt your upper studs and weld them higher up on the frame for a shock with 10" of travel.... have fun finding one of those that fit in there I am pretty sure there is only like 12 inches from my lower tabs to my upper stud
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 03-12-2008, 03:28 AM   #11
rotgg
that is what i was trying to explain to HotRodYJ
Old 03-12-2008, 04:18 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Have you tried the rear shock in the front ?
Or try this part number:
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-12-2008, 05:58 AM   #13
rotgg
i have a shock that will work i was just wondering what everyone was using
Old 03-12-2008, 07:59 AM   #14
bagged81
Signals in the bumper.
bagged81's Avatar
I use a lowered shock from ART, but my Z did not affect my shock mounting. I use a lowered shock becuase I have 3" spindles and bags. Maybe I am misunderstanding.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 03-12-2008, 08:45 AM   #15
bedsled71
bedsled71's Avatar
yeah im not understanding either because i have a 2 1/2 z but the stock shocks still let it lift up high enough..
bedsled71 is offline   Reply With Quote
Old 03-12-2008, 03:55 PM   #16
HotRodYJ
HotRodYJ's Avatar
Apparently I didn't understand all the parameters of what you where asking. So you need 10" of travel at the shock? An RE7 bag only has about 8" of total travel with no weight on it. You must have a really trick set-up if you've getting 10" at the shock. I'd love to see pics of that if you have them. That's a TON of travel.
Old 03-12-2008, 11:44 PM   #17
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I have a 3"Z and my shock mounts didn't change in relationship to each other. I need a shorter shock due to the bag placement in the control arm but I haven't picked one out yet.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
