th400 kickdown switch
I have given up trying to deal with getting the stock parts for my 72. Has anyone out there tried the Lokar kickdown switch set-up? Thanks for any info. By the way, great forum!
I have the B&M kickdown switch and it works pretty good. I got it because it is cheaper than the lokar but I think the lokar is a better one to have imo. If you want a pic of it let me know..
Devin
'67 C10 LWB FLEETSIDE, WEAK 305 , TH400, 3.73 REAR COLORADO SPRINGS, CO. |
Yea a pic would be cool! Hey I am just down the road in the Albany area
Over worked under paid
I have the Lokar set up, easiest thing I've done to the truck. A little pricey but just a small box the attaches to the trans. a cable to the carb. Connect to key on power, and plug into trans.
Sorry no pic.
Roger '69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears |
here is the pic hope it works!
I used a horn button for the kickdown switch mounted on the floor. To kickdown I just step on the switch it works like a dream
1969 GMC S/B S/S 3" drop |
I use the Lokar set-up , its nice but I had to drill a new hole in the throttle arm on the carb (edelbrock) to make it work right. When I used the stock hole for kick down it wouldnt kick down unless the throttle was almost wide-open. I drilled a new hole closer to the center of the throttle arm and now it'll kick down at about 80% throttle, much better.
No, Its not a 454 |
My other Love
I could never get that damn switch to work all i do now is drop it into second now
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
"Trucks with Class"
![]() Join Date: Jul 2000
Why couldn't you get the stock switch to work? The mounting bracket is already built into the pedal assy under the dash...The switch is only about $15 and two screws hold it on.
![]() Join Date: Sep 2001
I managed to find one for a stock 327 2bbl setup. Not easy.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
![]() Join Date: Dec 1999
I have the earlier ones that mount by the carb using back Qjet hole operated by a tab that comes off the carb,i think it was 71-2 that had under the dash.I even have a couple from stock 69 Big Block 2bbl Intakes.
400 kickdown
Here is what you need. (see picture) If you have the original gas petal it will bolt right on. It will adjust itself the first time petal is pushed to the floor. To hook up just run one wire to fused switch on circuit and the other to switch on trans. The switch can still be purchased at dealers. Hope this helps.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#13 |
My other Love
even with all of the wring it still wont work for me. It must be the soleniod in the tranny that is the only thing i can think of now
