Old 03-09-2008, 02:24 AM   #1
hotrodhomi
hotrodhomi's Avatar
air line through crossmember?
How did you run your air line for your front bags? Did you drill a hole in your crossmember? If so did you use a grommet or just wrap your air lines?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-09-2008, 02:43 AM   #2
PipsC10
PipsC10's Avatar
Re: air line through crossmember?
I drilled a hole through my crossmember and used bulkhead fittings to route the line. Came out real clean, I have not installed my motor or trans yet, but I don't think the lines will be too close to cause any problems. I plan on running hard lines down the frame rails to the tank.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 03-09-2008, 02:51 AM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I put a 90 on the bag and a whole in the rear of the crossmember with a grommet. Its been that way for about 4 years without any problems.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 03-09-2008, 09:47 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
You can use grommets, or another option is drill a larger hole and put a piece of fuel line through, then run your airline through that.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-09-2008, 01:10 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I drilled a hole, put in a grommet, slid a piece of clear hose over my line & ran all that through the grommet
No problems for me
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
