Old 03-09-2008, 04:15 AM   #1
desertPOS
desertPOS's Avatar
Beat to death: But..... tires.
I have a '69 C20 with stock suspension and no intention of dropping it. It has the 16.5 factory (I think) rims, but the tires are mismatched rollers that need to be replaced. I do a decent amount of fwy driving in the truck, would like to fill the wheelwells and get something a little wider, at least in the back. Looking for tire recommendations, I can't wrap my head around the proper way to measure tires when they're not measured in inches yet. Looking at the BFG T/As, but something with a decent warranty would be good. Not opposed to running smaller in the front, as long as they all use the rims I have. Any insight would be great...
desertPOS is offline   Reply With Quote
Old 03-09-2008, 04:17 AM   #2
desertPOS
desertPOS's Avatar
Re: Beat to death: But..... tires.
Only picture I have at work, I believe they're the stock rims. Looking to givi it a better cruising ratio on the freeway. Thanks...
Old 03-09-2008, 04:42 AM   #3
ofnaman
ofnaman's Avatar
I have 265 60 r16 bfg t/a's on my 3/4 ton wheels(mine are 16's). They fit nicely and look good. Type in tire size converter on yahoo or google and you can convert metric tire sizes to standard very easily, there are a ton of free tire size converters out there. hope this helps
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 03-09-2008, 06:41 AM   #4
desertPOS
desertPOS's Avatar
Thanks! Any pictures of your truck with these tires?
Old 03-09-2008, 06:59 AM   #5
stllookn
Saving 1 truck at a time!
stllookn's Avatar
33 x 12.5 x 16.5's on 9.75 inch wide wheels. They will go on 8.25-in rims which are more common. Forgive the wagon wheels on the Longhorn...temporary while tires are getting swapped onto the slots.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-09-2008, 08:30 AM   #6
Green Machine
Green Machine's Avatar
We are doing - for now - replacing the old 16.5 rims with stock steel 16 inch rims, most any maybe 73-87 3/4 chevy will have the 16 x 6.5 rims. 245/75/16 is a real common tire and fits nice and should be a little taller than what you have now. A 265/75/16 will fit on that rim and be taller yet. Maybe 265 on back and 245 on front ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
