Old 03-09-2008, 06:12 AM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Gas MPG Questions
I have a bone stock 350, 2.02 heads and nothing else. I am running a 600 cfm Edelbrock carb, 700R4 trans---as you can see nothing fancy...what kind of gas milage do you think I will see with this combination--on the highway 65 mph??
1971ChevyTruck is offline   Reply With Quote
Old 03-09-2008, 06:19 AM   #2
Gorn
Gorn's Avatar
Re: Gas MPG Questions
Between 8 and 20 MPH
It is better to live one day as a Lion then 100 years as a Sheep
Dingers Build Thread
Dingers Before Pic's
My 67 Camaro
Gorn is offline   Reply With Quote
Old 03-09-2008, 06:36 AM   #3
cdowns
cdowns's Avatar
depending on what rear you have// if 373 or so i'd say about 16mpg if your engine is tuned up properly
Old 03-09-2008, 06:56 AM   #4
griesel72
griesel72's Avatar
yeah, these trucks don't get too bad, my healthy 350 with a 308 rearend 4X4 and a 4 speed gets between 13 and 15, and the last time i checked, that is not much better than the new gm's
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 03-09-2008, 07:04 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
You need to look at your tire size, rear end ratio, and RPMs for the speed you choose. Once you know these, then you can figure closer what your mileage should be. If your tires are TOO tall, then you will work your truck to death getting up to speed and overcoming hills. If your tires are too small, then the RPMs will be high. Changing tire size is the equivalent of vchanging rear end gears. If you are geared too low, then you will run high RPMs and the mileage will be bad. If you are geared to high, the engine will work harder in a city type of driving, but will be smoother on the highway.
Is your exhaust and air cleaner restrictive on flow? That will change gas mileage a lot. Getting rid of the stock belt driven fan is worth a single MPG gain.
piecesparts is offline   Reply With Quote
Old 03-09-2008, 07:33 AM   #6
Zonaman
Zonaman's Avatar
I'm set up very much the same as you. I keep pretty close tabs on my mileage. The best I've ever done was Tucson to Phoenix (at about 65 all the way), no a/c. Got 13.8. I usually get 11.6, around 10 with a/c. that's combination city & highway. That's with an Edelbrock 1406 carb. I think the consensus around here is that the Qjet is more efficient. Myself I'm thinking of going to a tbi setup at some point.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 03-09-2008, 10:17 AM   #7
Mint68
Mint68's Avatar
Wow, I have a bone stock 70 Blazer with 82,xxx miles and 31" tires and 3.08 gears. I'm always amazed by the gas milage others are geting. I dont think I ever hit over 10, I seemed to always be in the 7-8 range. Hopefully the tires are throwing the odometer off and it is not counting correctly, because everytime I check it is painfully low.
Mint68 is offline   Reply With Quote
Old 03-09-2008, 10:47 AM   #8
Gorn
Gorn's Avatar
In addition to that:
The Jets in the Carb and your Cam shaft can greatly effect milage.
My 67 Camaro
Old 03-09-2008, 11:01 AM   #9
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
sarcasm at its finest!!!!
hahahahahahaha
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-09-2008, 12:20 PM   #10
1971ChevyTruck
I have a 3.73 rear end...
Old 03-09-2008, 12:34 PM   #11
72swb_327stroker_?
knuckle buster..
is it a posi?
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 03-09-2008, 07:29 PM   #12
MrGoodpliers
MrGoodpliers's Avatar
I've seen a few of these threads and I'm always surprised at how small the milage numbers are for the overdrive swaps. I have a 72 1/2 ton suburban with 350, dart s/r heads, mild cam, edelbrock intake and carb, 350th, 3.08 gears. 15 mpg highway.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 03-10-2008, 04:05 AM   #13
1971ChevyTruck
You an me both...there must be some heavy feet in here
