Old 03-09-2008, 07:31 AM   #1
jhow66
jhow66's Avatar
headlight adjusters
Are the adjusters the same on a 1965 GMC PU as those on '60-'61 Chevys? (dual headlights). Who sells replacements?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-09-2008, 07:56 AM   #2
joe231
joe231's Avatar
Re: headlight adjusters
here are both kinds
http://classicparts.com/products.asp?dept=200
CHEVY ONLY
Old 03-09-2008, 08:31 AM   #3
dedjr67
dedjr67's Avatar
If all you need are the plastic inserts and screws you can get them at any parts store usually in the help section
dedjr67 is offline   Reply With Quote
Old 03-09-2008, 08:39 AM   #4
jhow66
jhow66's Avatar
Thanks fellows, just what I needed to know.
Old 03-10-2008, 08:43 PM   #5
LILRED66
LILRED66's Avatar
Make sure the square plastic insert will fit into the square opening in your headlight mounting bracket. I have bought them before, only to find out they were not the correct size. You can also secure your existing plastic inserts with epoxy, if you can't find the correct size or find a good set of used ones.
LILRED66 is offline   Reply With Quote
Old 03-11-2008, 03:10 AM   #6
jhow66
jhow66's Avatar
Theses are for '65 GMC with 4 lights. They are differant then those on with 2 lights. Thanks anyway.
