Old 10-26-2002, 04:00 PM   #1
bmg
bmg's Avatar
Gas Pedal Bolt
I need to know if any of the local stores would have somin like this the one with the ball on the top that pushes into the pedal. Just drilled the old ones out and broke one of the new ones puttin it in. Like say napa, chucks, or carquest. Part # would be a great start if anyone has this.
bmg is offline   Reply With Quote
Old 10-26-2002, 11:08 PM   #2
lpaine
lpaine's Avatar
BMG- I have the same problem with my 69'. I was thinking of adapting the 71-72 gas pedal to it, it seems like a better setup. I plan on going to the wreckers(yet again) to have a closer look to see if that'll work- or if you just wanna keep it original you can order a bolt from LMC truck (Part# 30-1101) it's only $3, their number is 1-800-222-5664. Good Luck, Lewis.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 10-27-2002, 01:11 AM   #3
bmg
bmg's Avatar
Yeah i know they are cheap, but costs 11.00 to send here in Alaska. Thats the kicker, sucks ass. Was looking at making on a machine lathe with 1\2 stock maybe that will work. If not i will make somin work for the other side. Didn't want to switch it out. have to chane the whole under for brake and all. Not woth the hassel. If no luck just keep driving on rod.
