Texas Big Wig
Few questions
Ok, I have a few questions here
#1 How much can I notch the frame & still be strong enough to haul something around 3-4 thousand pounds ??? (I plan to plate the top / sides & box the inside, & use a piece of 4" 1/4" wall pipe) I just need to know how deep I can make it & still be safe #2 At what point is it advantageous to flip over the trailing arm mounts ??? (I have a one piece drive shaft, so I don't have a carrier bearing to flip) #3 What is the optimum angle for my shocks to run at (I am building new shock mounts) #4 Last but not least, if you were building a long panhard bar to run from the frame to the passenger side trailing arm would you use rubber bushing syle ends or heim joints ??? Thanks, Matt P.S. I do not want a step notch, just something I can build that is hopefully deeper than a bolt in notch ![]() Last edited by Spray-Bomb; 03-09-2008 at 11:17 AM. |
#3 | ||||
Re: Few questions
