Old 10-26-2002, 04:42 PM   #1
mikep
Used to have a truck
mikep's Avatar
5 speed transmissions
I cant stand automatics. Is there a decent OEM manual overdriven 5 speed that can handle 3/4 ton type loads without grenading. I'd like to up my mileage a bit but I dont want to install a transmission that is weak piece of crap like a T5. I'd like to use as many original components as possible too so getrags are out of the question. Is there a OEM 5 speed that might even bolt up to a chevy bellhousing?
No truck :-(
mikep is offline   Reply With Quote
Old 10-26-2002, 07:57 PM   #2
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
I've been looking at the NV4500 (Chev/Dodge 3/4 ton 5 speed), but it always ends up being expensive. Sure would be cool, though..
I think the older ones (93-95?) bolt straight up to the chevy bellhousing, you just need to convert to a hydraulic clutch system.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 10-26-2002, 08:02 PM   #3
nu2-72
I was looking for info also. Found some useful stuff at Advance Adapters site. They appear to have a bellhousing for manual clutch and one for the hydraulic but both are pricey.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-27-2002, 12:31 AM   #4
Jesse 67 c-10
Jesse 67 c-10's Avatar
I'm pretty sure going 5 speed and using as many original components as possible are inversly related! kind of like milage and hp, I used a getrag 5 spd from a half ton, the lighter weight model, no granny gear, seems to be holding up ok to my 327, but I'd go for a nv4500 for something heavy duty, the later model 4500's don't have as low a granny gear either so they would be great. or if you can find a getrag from a 3/4 t, I believe there is such a thing, getrags are great trannys, shift very nice! mine does at least. any 5 spd from a gm truck up to 98 will bolt to an old sb. after that the motors changed so the bolt pattern would be diff. All new 5 speeds (as far as I know) require a hyd clutch, can be done, I did it, also most newer ones have an elec speedo output. This is what I know about the gm ones. You'll spend quite a bit more doing this conversion than on say a th350 but it's worth it! otherwise you can shell out for an aftermarket tranny, richmond gear? how bout a lenco?
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 10-27-2002, 03:24 AM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
I say if you're going to go through the hassles of adapting electronic to mechanical speedos, locating shifters, and a hydraulic clutch...get a T-56 out of a fourth-generation Camaro or Firebird.
They're tough as nails (used in all manual-tranny V8 F-bodies, 1993 to 2002, along with all Dodge Vipers, Mustang Cobra Rs, and the new SVT Cobra) and should be relatively easy to find. Plus, they're a LOT cheaper than a Richmond 6 speed.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 10-27-2002, 08:46 AM   #6
Lumpy
2 tons of fun
Lumpy's Avatar
Thumbs up
Check out the Tremec 3550 or TKO. I am hoping to get one someday Cya.....Lumpy
http://www.fortesparts.com/tremec/index.html
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H
Three Rivers, Ca
Pics at: http://www.cardomain.com/id/lumpy454
Lumpy is offline   Reply With Quote
Old 10-28-2002, 01:18 PM   #7
ThreeQuarter
ThreeQuarter's Avatar
The NV4500 sounds closest to what you're looking for. And Jesse is right; even the oldest HD 5-speed trannies are pretty recent. Chevy didn't have an OD tranny for HD pickups until '92.
The NV4500 in GM pickups comes in two forms. The early models ('92-'94 or '95--haven't figured it out for sure yet) have lower gears: 6.34:1 granny, and correspondingly lower in other gears, except OD. The early years have different front-of-the-tranny-case bolt patterns than the Dodge NV4500s of the same years. In either '95 or '96 GM gave NV4500s numerically lower gear ratios (higher gears) to match the Dodge models, and changed the case bolt pattern also to match the Dodges. Both type os NV4500s will bolt to a SBC.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 10-28-2002, 08:02 PM   #8
mooneyes
mooneyes's Avatar
how much $$$$$$ do those t-56's go fo used????????????i keep hearing how strong they are..anybody run one behind something with some major ass????????
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 10-28-2002, 10:11 PM   #9
Project1970
14.1 @ 96MPH
Look on eBay - I think they're just short of $1000 or so. A lot of the ones you see are still connected - and for sale with - the LT1 or LS1 that came out of the car with it, though. Just have to put both in, I guess
Old 10-28-2002, 10:18 PM   #10
guitarman
Do it well or don't do it
guitarman's Avatar
Mooneyes4b, I run a t-56 behind a .030 over BB FI roller motor in a 3200 lb car and it holds up fine to 500+ hp.
Edit: I just re-read your post 11/01/02 you asked how much? I paid $2200.19 delivered to my house. Then you must buy a bell housing and hydraulic throw out bearing a mastercylinder and clutch pedal assembly a flywheel, and pressure plate and clutch. Would you believe they don't even give you a shift knob.
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
Old 11-01-2002, 01:39 AM   #11
chevyforever
Some like em' long!
tranny help
if it were me, i would opt to find an early model NV4500,, if you can get one with the bell housing already attached, go for it cuz then all you have to do is convert the clutch to hydraulic and it will bolt right up to the engine. the Nv4500 is tough as nails because of the cast iron case, nothing like the wimpy getrags.
good luck
1971 chevy c10 lwb- 300 hp 350 crate motor, soon to be more with ported and polished 62cc chamber 461 double humps, TH400, 3.73 posi, used to be my uncle's truck
1972 chevy k10 lwb- 350,4 spd, old and tired, dad bought brand new and is now mine
1968 chevy c20 lwb- 327, 4 spd, was originally a 50th anniversary truck
1990 GMC K1500-just my runaround truck
1982 Chevy K10 shortbed, new motor and new paint, another project in the mix of the others.
IMPORTS SUCK!
chevyforever is offline   Reply With Quote
Old 11-01-2002, 01:51 AM   #12
mikep
mikep's Avatar
I dont know oo much about the nv4500's. What did they come in ?
No truck :-(
Old 11-01-2002, 10:19 PM   #13
chevyforever
Some like em' long!
i am not for sure which dodge pickups came with the NV4500, but i know that the early model NV4500 came in both 1/2 and 3/4 ton Z71 packaged chevy and gmc pickups from 1992 to i think 1996. they are also found in non Z71 trucks. they are easy to identify because they are cast iron case and not aluminum, like the getrags.
IMPORTS SUCK!
