Old 03-09-2008, 08:55 PM   #1
Nima
Blue 67
Can this combination be used in my truck?
Hey everybody:
Can I use 5.7 engine and R4 700 out of a 92 cadillac d'elegance in my truck? The guy says it has all the serpentine belt and brackets and wiring. If yes, at 56000 miles, how much would you ay is worth?
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 03-09-2008, 09:01 PM   #2
67shortie
Green club
67shortie's Avatar
Re: Can this combination be used in my truck?
92? I believe that car is front wheel drive with the northstar engine. You might use the engine, but the trans, nope unless you want the first FED truck on this site
The only Caddy that year for rear wheel drive is the huge tuna boat (can't recall name) but that has the LT-1 and 4L60 I believe, and that can be transplanted.
Worth? Don't know but below a grand in my opinion.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-09-2008, 09:11 PM   #3
67shortie
Green club
67shortie's Avatar
If it's this car you should be able to, this is listed as a '92
That was the wrong image, try this:
Old 03-09-2008, 09:48 PM   #4
Andy4639
Old member
Andy4639's Avatar
I think it can be done. With enough money and parts and not being afraid to explore the possibilities. This place can help you out.
http://www.chrfab.com/projects.htm
Just a taste of what can be done with plenty of money.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-09-2008, 10:58 PM   #5
Nima
Blue 67
FWD was what I was concern about. If it is FWD, isn't the engine mounts differently? Then I can not use the engine either? Second, If I can use engine, what the use for tranny?I am not that mechanically experinced to do major fan work.
Old 03-09-2008, 11:00 PM   #6
Nima
Blue 67
Few other things. Engine and tranny are out of the car therefore I can't what they came out of. Second, he says engine has only 60000 mile on it, third, he wants $700 fot the combo.
Old 03-09-2008, 11:57 PM   #7
67shortie
Green club
67shortie's Avatar
From my memory, for what it's worth That large car should have an LT-1 and a overdrive auto which is a decent combo and take a closer look at it.
If the engine says northstar on the valve covers you have a front wheel drive combo that would be not usable.
Someone else chime in here, is the northstar engine compatible with a Chevy trans? And does anyone sell mounts for this engine?
