? on front window
I have the little triangle window on the front of my truck, how do I remove the little chrome peice that opens the triangle window (the lever thing). Dont know what its called so heres a pic of what Im talking about (not my truck)
Re: ? on front window
Reason I am removing is because I am tining the windows and cant do it with the lever on there.
Green club
There is a small pin that holds it on there to the shaft. Look on the lever itself, and you will see a 1/16 or so small hole, in there the pin will have to be punched out. A small nail and a hammer is what I used....
Then you can unbolt the post from the glass.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
Cool thanks 67. Just found a small allen wrench and punched it out with that. I appriciate your help, took me 30 seconds to do it after you help, I was lookin at it for about 20 minutes earlier today and couldnt figgure it out (pin had a litte mud on it) lol.
Green club
You are welcome Tonka, that is what this place is all about.
Good luck with your project ![]()
