Old 03-10-2008, 01:39 AM   #1
ChopperDr
New springs too high
I took the 40 year old coils out of the front end of my 66 and put in some CPP 1 inch drop springs. I knew it would raise it. Its now about 1 1/4" higher than it was with the sagging old springs. I needed to tear into the front spindles to see what year they came from, it has discs up front. I'll order some dropped spindles on monday. How much should I expect the new springs to settle? I might end up cutting them down if they wont get the front end down enough.
Other than smacking my thumb with a hammer knocking the ball joints loose, I was pleased to see everything in the front end in great shape. It was changed over to the 73 and up components. Now I know.
Will the new spring drop a little?
Chopper
ChopperDr is offline   Reply With Quote
Old 03-10-2008, 03:37 AM   #2
royo
royo's Avatar
Re: New springs too high
Yes it will . just drive it around. then if it dont settle cut it
nickle and dime
royo is offline   Reply With Quote
Old 03-10-2008, 06:02 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Are you positive they seated?. Usually you hear a bang when they do!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-10-2008, 10:20 AM   #4
slammed1
1972 Chevrolet SWB
slammed1's Avatar
its common occurrence for a new drop coil to not drop a truck the advertised amount especially after the stock coils had 40 years of sag.new coils will settle usually 1/2" a while after installation but as stated earlier you can trim a coil to the desired height,and is not as taboo as many would like to think.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-10-2008, 06:03 PM   #5
ChopperDr
Thanks for the replies. I had an idea that the springs would raise it up. I could tell from the angle of the controll arms they were either collapsed or cut. I found the new springs on Craigslist, too good of a deal to pass up. Its supposed to be nice today, I'll put a few miles on the truck. Once the dropped spindles get here we'll see where the hight is at, I might have to do some cutting.
Chopster
Old 06-07-2008, 02:35 PM   #6
txinliner
txinliner's Avatar
could not agree more
txinliner is offline   Reply With Quote
