Old 03-10-2008, 06:59 AM   #1
rickyrqacer
Toasted Dually Club
A couple of "what is it's"
Im replacing the underdash wiring harness in my 87 CC Dually, this is my second time this week doing this as the first harness I had finished installing and was ready to start testing, and the engine compartment side of the wiring harness was a different style .. it's a good thing I bought two of them, one from a forum member here ... anyways, I took photos of everything that I thought would be tuff to remember, but this following item, im stuck on .... what is it and where's it go ?
Secondly, there's this wire comming off the back of the dash cluster, it ran down to the ashtray area, but was not hooked to
anything, could it be like a fiber optic for the ashtray?
rickyrqacer is offline   Reply With Quote
Old 03-10-2008, 07:12 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: A couple of "what is it's"
ok first thing is the computer for ur spark on the distributor (going to need it if ur installing factory stuff again). (also it goes under the dash near the glove box.) and the cable on ur instro panel is for ur ash tray its a light cable (light runs through the cord and to the ash tray so u can see were to put ur cigarette.) its kinda like fiberoptics. (the cable goes into a little white clip near ashtray )Hope this helps
if u need photos i can get them i have an 86 same stuff for the most part
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-11-2008, 03:51 AM   #3
rickyrqacer
Toasted Dually Club
Thanks Srudy, I got that part figured out , Im dowm to 2 wires that I have no idea where they belong, I started teh truck today, every runs as far as I can tell and it didn't start on fire !!!
this wire come out of the stearing collum, it's balck in color, flat with two leads ....
Next set is are these two connectors, I think the 3-wire one is factory radio but the pink and purple one ? there are no "loose" connectors left over ..
Old 03-12-2008, 01:23 AM   #4
rickyrqacer
Toasted Dually Club
Anyone have a clue, none of my manualy. schematics show this stuff ...
RR
Old 03-12-2008, 01:30 AM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Top wire is cruise control.
Bottom black connector is the radio.
I don't know the other one off the top of my head.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-12-2008, 05:41 AM   #6
rickyrqacer
Toasted Dually Club
Thanks CK, I did look at Classic Parts and the Cruise Control wire end matches, by chance, do you know where it plugs into? I see nothing in that area that it could go to ...
as the black connector, your right on fopr the radio, thats where I'll hook my stereo to ... the other, maybe some day it's need will show up ...
Old 03-12-2008, 07:03 AM   #7
rickyrqacer
Toasted Dually Club
**Update **
I found where it belongs, hidden off the brake pedel support arm, all is sorta well for this part ...
Old 03-12-2008, 03:41 PM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: A couple of "what is it's"
The black box in the very first pic has nothing to do with the spark for the distributor..........It's the micro processor for the cruise control.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 03-18-2008, 11:29 AM   #9
rickyrqacer
Toasted Dually Club
Bruce ...by chance do you know in what area of the dash that black box mount to? I just don't see anywhere that it belongs ...
