1.02 lateral g's!
What would it take for a swb 2wd to achieve such stats? Or somewhat close? What is the best suspension for performance oriented individuals out there? How well do bags perform when you dont care if you can slam your frame and tuck 22's? I want a truck I can take to the track and win against fox bodies or the like.
Yup, I'm comp-useless
Re: 1.02 lateral g's!
That's a steep request from a pick-up, unless you are doing a full custom frame.
The weight bias of a pick-up is just so far from the ideal 50/50. Relocating the battery to the rear of the truck and a whole bunch of other mods to get the weight bias closer to 50/50 would help a bunch, then there is the whole issue of COG(centre of gravity). Drop that thing as close to the ground as you can, but still having useable suspension travel with as little deflection as possible(ie poly urethane bushings, full blown tubular control arms). Anything is possible, as long as your wallet/bank has the fundage to allow the amount of modification needed to achieve these lofty goals.
1972 Chev Suburban(ongoing driveable project) 2010 Harley Wide Glide 1996 Subaru Outback(daily beater) !992 T-Bird Super Coupe(yet, another project) 1995 GMC Suburban(will be for sale, soon) 1995 Dodge 3500 Club Cab(Cummins 12V) 2001 Freightliner(Cummins Powered Money Maker) |
my fuel tank is now under my bed, a little better weight distribution. is weight distribution the biggest obstacle in these truck? I read somewhere that the rear trailing arms are the same that nascar used in their cars in the early 70's...so i was thinking that this truck should be able to handle with the best fullsize 4000lb vehicles out there. And with the multitude of aftermarket suspension components I would think you could get a truck that is a lot of fun around a track other than a 1/4 mile. The 1.02 lateral i know is high aspirations, but what do you think is possible with a little bit of money and know how?
#4 | ||||
Could a 64-72 GM truck be tweaked to handle like late model cars? Sure . . .... & then you could haul a bunch of stuff around in the back when your done playing slot-cars. Sounds like a fun project!
So, in your opinion what would you recommend for an incredibly well handling 68 daily driver? I know that 1.0+ lateral is pretty impossible, but im looking for the ideal handling characteristics needed for these large truck to be able to hug the roads as well or better than a sports car designed to. I guess im curious how good can these trucks handle? I mean how good is the stuff out there?
Saving 1 truck at a time!
Google Art Morrison Engineering. I think they have a frame/chassis that will do it...G-Force.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Old member
I'm no engineer by no means but for the rear end in these trucks you can move the shocks out further on the axle. Have the front of the trailing arms moved further out from the center of the truck.
A four link setup would be the best though I would think with a corvette rear end installed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#8 | |
As was suggested, AME offers some incredible frame/suspension set-ups. My friends can build stuff from scratch but have used AME's stuff on several vehicles. The downside is the cost involved since it's usually out of budget for daily driver type builds. The stock stuff can work well though. Swap in a Porterbuilt Streetrods 'Dropmember' & you get lower center of gravity w/updated R&P steering w/o having to use dropped spindles which are notorious for compromising 'bumpsteer' in their effort to get the vehicle lower. If there's a downside to the Dropmember, it's that it's only available for air suspension. If sticking w/the OE parts, some urethane bushings, a large sway-bar, & decent brakes will help too. Help us out w/your budget & everyone can offer suggestions that are better aligned w/your goals & finances.
#9 | |
![]() Join Date: Aug 2005
There's no reason you couldn't run coilovers with the shockwave dropmember. |
I am a Referee of life.
Custom tube frame,engine setback, and suspension froma Z06 might start you in the right direction.Use some fiberglas parts to lighten it some more and move as much weight to the rear as possible.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
First off thanks for all the input. And no , i dont have the budget for custom tube chassis and corvette parts, let alone the know it all to put it all together. my budget realistically right now is probably around $3000, give or take, for suspension alone, front and rear.
Call me old school, but i was thinking that coilovers instead of bags, bags seem to be synonymous laying frame, not pullin g's. A four link setup would be the best though I would think with a corvette rear end installed. How could I use a four link with an independent rear axle? NEW IDEA: im gonna look up prices for the corvette rear transaxle. Then i could move the tranny to just in front of the rear axle, shifting weight back, and getting a six speed. Has this been done before? |
So i looked at Mr. Frizzle's 61 c5 and have decided that although ambitious, not realistic for me. btw Frizzle, does that beautiful Frankenstein drive? how does it handle?
#13 |
Old member
Here are some good reads
http://www.customclassictrucks.com/h...uck/index.html http://www.rodandcustommagazine.com/...ion/index.html 4 days left at $1000.00 http://cgi.ebay.com/ebaymotors/67-co...em220209698979
#14 | |||
The coil-over idea is a great idea, I just didn't include that scenario until there was a budget thrown on the table. As for bags being "synonymous" w/laying frame, check out AirRide Tech's road course activity @ many of the GoodGuys events. They're pushing to change that outdated logic that air is only for draggin frame by developing kits that offer lower ride heights, are adjustable, & ride better that typical dropped spring applications when compared model for model of vehicle. Some of the fastest cars around the road courses they help set-up are 60's muscle cars on airbags (as fast or faster than late model f-bodies or vettes). It's the overall packages they offer that work well & make the vehicle handle better. Quote:
#15 |
In my time racing, I think the most overlooked part by newbies is tires. Its easy to throw money at parts, but some people are reluctant to buy good tires. Also, imo, for racing any street tire is inferior to a race tire. There are just too many comprimises for a street tire.
That being said, 1.02g's for a truck is a VERY high bar to get to. I think a more reasonable goal would be around .90 - .92g's. I believe this is about where the Ford Lightnings are from the factory and should be acheivable in trucks like ours. My goal for my truck is to be able to out do a Ford Lightning in all catagories (accelleration, handling, braking). |
#16 |
![]() Join Date: Nov 2004
Z06 vette, Lamborghini, and viper are in the 1.0 to 1.1g range....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#17 |
Somebody (Road and Track, Hotrod, Motor Trend...) got 1+ g from a 3000 lb G-body back in the late 80's or early 90s. I don't see why a 4000 lb truck couldn't approach 1g. It would definitely need some weight redistribution to the back and a lower CG. Aluminum goodies under the hood will shed a few pounds up front too.
#18 |
I've seen people hit a full g with a 4000+ lb b-body. I know they have much better weight distro than a truck but I think with the right combo you could hit a .9+ no problem. As mentioned though tires are key.
#19 |
Active Member
My CTS-V can do a 1.0g it even has the gauge to prove it. Very tough to do it in our trucks.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
