Old 03-10-2008, 09:48 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Bolt pattern question
Has anyone had their front rotors re-drilled to a different pattern, can it be done ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-10-2008, 09:52 AM   #2
SCOTI
SCOTI's Avatar
Re: Bolt pattern question
Yep. My 74 has 1.25" HD truck rotors that were re-drilled to a car pattern.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-10-2008, 09:54 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Is this something my local machine shop would be able to do ???
Sinister
Killer
Old 03-10-2008, 10:18 AM   #4
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I seen some stock car (oval track section) rotors in Summit the other nite that were drilled mainly for 5x5 pattern with studs but had a 5x4 3/4 pattern also drilled if you wanted to usse that pattern....they were cheap also.
Re-drilling bolt patterns on axles,rotors,drums,hubs and more are easy for a machine shop but price will determine if you know someone there or not.
I am planning on running a Dodge Ram pattern of 5x5.5 stock to a 5x5 or 5x4 3/4 soon.I have machine shop friends though.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-10-2008, 11:04 AM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Any machine shop would be able to do it IF you can get them to do a small job like that. Billet aluminum adapters is another (usually cheaper) alternative. My brother has run 5 on 4-3/4 rims with adapters on his '78 GMC drag truck for about 8 years now with no problems.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-10-2008, 08:15 PM   #6
IBAPIGFARMER
IBAPIGFARMER's Avatar
I run Street stock race cars and always drilled my own. Take your time to mark out holes on a pattern and drill with a drill press.
IBAPIGFARMER is offline   Reply With Quote
