![]() Join Date: Jan 2006
Overhauled my drive shaft
Re: Overhauled my drive shaft
you might want to reinforce that bearing carrier, they are a lot weaker then the originals and break (so i am told) without reinforcing them.
You should weld all the way around the seam on the top where it mounts to the frame, the two peices are only spot welded. Then you should take some band iron and weld it from the side of the mount, down and around the bearing housing part and up the other side. The guy who told me this hasnt broken one since he rienforced it. Ill try to get a pic of mine up so you can get a better idea of what im talking about. |
![]() Join Date: Sep 2005
i installed a carrier in my drive shaft and it came from orielys it lasted 4 months before breaking got another one from advance lasted 3 months advance gave me another one i took the shields off this time and its been fine since
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
i had to weld mine from oreily's, then that melted the rubber a little, and now the driveshaft drags on the rubber. i need to fix that
I am running a stock 260hp/350. does more h/p put more stress on the center bearing?
the front U-joint is way too big. I am running a 4 speed saginaw car tranny. Is the front U-joint the same size as the center and rear? I assume the joint NAPA gave me is for a truck tranny yoke.
Yea I know that the bearings come off, even with them off I couldn't get the U-joint in.
its all about the +6 inches
HP doesn't effect the bearing if everything is lined up properly.
I would take that to a drive shaft place and have them spin it, a mild off ballance condition may go unoticed, but could damage things like the rear diff and the brass bushing in the tailshaft of the tranny. |
