Old 03-10-2008, 11:33 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
quick release exhaust
i use some 2-1/2" corvette ram horn exhaust manifolds on my 1970 2wd blazer. i need to remove my exhaust manifolds often when im wrenching on my baby. the 3 stud connection under my manifolds is always super tough to line up. i like the 2 bolt ball and socket connection that ford uses on the h-pipe that they put on their 5.0 H.O. cars in the 90's. i cut my exhaust pipe a little bit behind my motor at a good location where i know i can reach the pipe easily. then i weld in the ford ball and socket connection. the h-pipes are easy to find in wrecking yards under t-birds that originally had the H.O. motor installed. then i am able the bolt and line up the 3 stud exhaust donuts on my manifolds on a bench where i can reach them easily. now i can drive my chevy without sounding like a retard with an exhaust leak.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 03-10-2008, 09:08 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: quick release exhaust
Cool approach. Got any pics?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-17-2008, 11:00 AM   #3
13lazer
13lazers' blazers
13lazer's Avatar
i will get some uploaded, its not easy to to get good pics without a lift. i will work on it over the next few days.
1970 2wd blazer
