Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-10-2008, 12:18 PM   #1
7T2 K10
7T2 K10's Avatar
Doors locked & keys are lost
My sister has a 91 s15 , that she's giving to me. only problem is they cant find the key for the door locks. I bought a slim jim, but i fooled with it for about a hour , then gave up . so before i went back over to give it another try i thought i would see if any of yall had any tips , tricks or ideas?
Maybe i wasnt holding my mouth right ?
lol
7T2 K10 is offline   Reply With Quote
Old 03-10-2008, 01:16 PM   #2
corn
Re: Doors locked & keys are lost
No key for the doors? The ignition key is the same key used for the doors.
corn is offline   Reply With Quote
Old 03-10-2008, 01:24 PM   #3
89 crew
Call either a lock smith or a towing/ recovery company. They are cheaper than a window. a slim jim has a chance of breaking the linkage inside of a door if used wrong. a lock smith will be needed unless you decide to change all the locks. If you just want it open, a towing / recovery company can get it open for you. If the ones there are like the ones here they can be in the car in less than 30 seconds. It will take longer for you to identify it as the proper car, than it will take them to open it.
89 crew is offline   Reply With Quote
Old 03-10-2008, 05:13 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
does this have a sliding rear window with the plastic "buckle"? there is a kit to replace those in case someone uses a screwdriver to pry it open from the outside. wink-wink
68C15 is offline   Reply With Quote
Old 03-10-2008, 06:02 PM   #5
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
It's a 1991, mate. Same type of keys as the 73-87 C10-C30's. Mine's a 1993 and I keep trying the key from it in my truck they're so much alike.
And to the OP, I agree with 89 crew, it'll take you longer to identify the truck as yours than it will take him to get in. I've never had to have it done, so can't tell you the cost, but I don't imagine that it'd be anywhere near as expensive (on your wallet or your time) as breaking something on the vehicle trying to do it yourself (and screwing it up like I would if I tried).
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 03-10-2008, 09:25 PM   #6
7T2 K10
7T2 K10's Avatar
Thanks guys . i think i will go over and mess with it for awhile today . if i cant get it , looks like i will be calling the locksmith monday morning .
Old 03-10-2008, 09:40 PM   #7
454_72_4X4
454_72_4X4's Avatar
Any you-pull-it type junkyards in your area? LOL
Windows are cheap!
Or you can do the same as the the local towing company did my 93. Small wedge at the top rear of the door, and use a smooth 1/4" or so rod with a hook bent on the end. Wedge the door open just enough to get the rod through ad then reach in and pull/push the lock knob.
I've did this to my truck once myself after I watched the towtruck guy do it at Menards parking lot the time before....
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-10-2008, 11:06 PM   #8
corn
I think you have to move the rod toward the front of the truck to unlock it.
Old 03-11-2008, 12:55 AM   #9
2manyprojects
2manyprojects's Avatar
If you have AAA plus they used to open them for free. I drove a tow truck and did plenty of them. If not see if you can find a cheap lock out kit. S10's are easy to get into. The tool you need will be a rod thats straight for about 12 inches then turns up into a half moon with a triangle on the end. wedge the door slide the tool inside the glass over the door panel and move the lock. I dont have my kit here to take a pic of the tool. If you need one I can do it tomorrow.
2manyprojects is offline   Reply With Quote
Old 03-11-2008, 09:43 AM   #10
7T2 K10
7T2 K10's Avatar
I'M IN !!! lol Went over today a fooled with the slim jim with no luck. then was lookin in the bed of the truck trying to find something i could use. I found a broke cb antenna about 4ft long. bent me a lil hook on the end , and i was in it in about 10 minutes. Went inside & got the ignition key from sis , but the battery was dead from sittin . oh well always something.
Thanks to all who replied
Brian
