Senoir Member
Another exhaust question
I finally got the 2 1/2" stainless pipes and 50 series delta flowmasters on the 402. I have the original cast mainfolds that are 2 1/2" outlet, and the heat riser valve on the passenger side (it opens and closes by hand). The truck runs & sounds great.
My question is...The tailpipe on the driver side is noticeably hotter than the passenger side, is this normal? I did not notice this with the last system. Maybe the heat riser valve is not opening when it gets hot, I have not checked that. Thanks
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Re: Another exhaust question
I would take that riser out.
Senoir Member
Just in case anyone searches this...My heat riser valve worked properly by hand when cold. But, when it was hot it was stuck closed. I tie wired it open, you can't really see the wire and it looks original. Both sides heat up the same now and it runs btter & smoother. Didn't really notice it running funny since everything is new and it's been about 16 months with the resto. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 Last edited by gregbr; 03-20-2008 at 07:58 PM. |
