03-11-2008, 12:48 AM | #1 |
Will it run today?
Door Panel Help
Hey Guys and Gals,
I'm in the process of replacing my armrests and have run into a small issue. A couple of the door panel screws were frozen, so I had to drill them out. I find at most of the larger suppliers the actual door panel screws and washers, but what I can't find are the little clips/nuts that those screw into. Any idea what those are officially called and where to get them? Thanks!
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! |
03-11-2008, 01:00 AM | #2 |
knuckle buster..
Re: Door Panel Help
i found mine at an autozone in the nuts and bolts isle. if not how about the wrecking yards?
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) join the the smilies fight club |
03-11-2008, 01:19 AM | #3 |
Gone to greener pastures
Re: Door Panel Help
Any decent auto supply should carry them.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
03-11-2008, 03:18 AM | #4 |
member #16
Re: Door Panel Help
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
03-11-2008, 05:11 AM | #5 |
Old member
Re: Door Panel Help
If your talking about the clips that slip over the metal and center up in the hole then go to LOWES in there hardware area in the drawers they have all sizes. They aren't factory but I use them all the time. Fender bolts whatever.
