Old 03-11-2008, 03:13 AM   #1
HotGMC
Is Backfire Necessarily Bad?
I searched some threads, and didnt find anything about my particular "problem".
I just want to know if its necessarily a bad thing, my truck backfires when i rev it out(in park or neutral, not while in drive and smashing the gas) and usually its a few "Pop pop pops". i dont believe its my engine, but i only hear it below me and no from the engine area. i actually kind of like that Mean hoarse sound that the backfire makes. but could it be excess gas burning in the exhaust? or mabye oil or something. plus everytime i start up my truck, it shoots out a decent amount of smoke(not really thick) but its white.
figured some of you guys could give me a heads up. im going to get a video of my exhaust hopefully so i can post it on here. thanks again.
HotGMC is offline   Reply With Quote
Old 03-11-2008, 06:18 AM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Is Backfire Necessarily Bad?
If it is a fast crackling popping sound out the exhaust- you probably have too much timing advance at high rpm. I've seen some low compression engines that are more responsive under load when set like this- but in general- not good. Detonation from too much advance under load can break piston ring lands. Sometimes you won't even hear it pinging.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 03-11-2008, 11:30 AM   #3
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs down Re: Is Backfire Necessarily Bad?
Not a good thing in the long run.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-11-2008, 12:03 PM   #4
El Jay
Gone to greener pastures
esll.
Show and tell.
What a great way to make a point!
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-11-2008, 06:00 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by HotGMC View Post
I searched some threads, and didnt find anything about my particular "problem". .....but could it be excess gas burning in the exhaust? or mabye oil or something. plus everytime i start up my truck, it shoots out a decent amount of smoke(not really thick) but its white.
I had similar problem on my truck and it turned out to be a bad spark plug.
Usually, or most commonly, a popping sound in the exhaust is unburned fuel. But in this case you should check a few things. You could have a combination of problems???
The first thing I'd do is a compression/leak check to make sure your white smoke is not water seeping into your cylinders and or bad valves. If the white smoke shows up after you run it for a while, then it could just be condensation evaporating when the exhaust gets hot...
Then I'd make sure the carb isn't running too rich (dark gray to black smoke).
Next I'd check and/or replace all ignition components. Plug wires, plugs, distributor cap and rotor, etc...
68gmsee is offline   Reply With Quote
Old 03-11-2008, 06:02 PM   #6
greasy68
greasy68's Avatar
exploded muffler........I would say someone had a little unburned fuel. That is the worst I have ever seen.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 03-11-2008, 09:36 PM   #7
Jim_PA
Looks like what we did to a couple of mufflers after a good key-drop (Cruise down road, shut off ignition. Pump the gas pedal a lot... turn key back on... KABOOM!)
Jim_PA is offline   Reply With Quote
Old 03-11-2008, 09:59 PM   #8
HotGMC
ESLL: i bet that was a fun sound to hear haha. i am going to be checking into a few things today
Old 03-12-2008, 02:26 AM   #9
EAST SIDE LOW LIFE
I thought you would like that.
esll.
Old 03-12-2008, 02:34 AM   #10
krazy_texan
krazy_texan's Avatar
well what if mine shot flames out the pipes when i would let off the throttle on the highway
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
