Old 03-11-2008, 03:42 AM   #1
rick0312
rick0312's Avatar
Can anyone ID my rear diff?
Limited slip? What type?...Thanks
rick0312 is offline   Reply With Quote
Old 03-11-2008, 04:33 AM   #2
john
member #16
john's Avatar
Re: Can anyone ID my rear diff?
From what I can see, it looks like an open Eaton.
john is offline   Reply With Quote
Old 03-11-2008, 05:59 AM   #3
rick0312
rick0312's Avatar
it's a 12 bolt cover.
Old 03-11-2008, 07:19 AM   #4
rick0312
rick0312's Avatar
hand written number on ring gear looks to be 2355. i divided this number and got 4.11 gears? These gears were stock on the 1/2 ton.
Old 03-11-2008, 07:26 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that gear could be had as an option, or standard if the overdrive tranny was requested.
Old 03-12-2008, 11:48 AM   #6
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I have yet to see a number like "2355" be used to determine gear ratios.
Most gears sets have a number like 41-11 which equals a 3.73........41 ring gear teeth divided by 11 pinion teeth. The numbers are there just have to be found. If you cant find them look at you ringgear and lace a chalk or grease pencil mark on one tooth then count them,then reach inside best you can and mark a pinion tooth so that you can count those.
The old method of raising a wheel or two off the ground really only applies to Posi type rear diffs where both rear tires will spin equally.........I know many many many have done the spin one wheel and watch driveshaft but a "open" style rear diff will have spider and side gears turning also while one wheel is off the ground giving false info.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-12-2008, 11:51 AM   #7
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Also with such a thin ring gear I can almost bet your pinion has 10 or more teeth which will probably equal out to be a 3.73 or less,as in maybe closer to 3.08............most highway gears will have a thin ringgear with a large diameter pinion where as non highway(performance gears) gears will have smaller diameter pinions with 10 teeth or less and thicker ring gears.
Old 03-14-2008, 06:57 AM   #8
rick0312
rick0312's Avatar
thanks slammed! I'll count them.
Old 03-14-2008, 07:49 AM   #9
rick0312
rick0312's Avatar
you were right slammed...41 teeth on the ring gear and 11 on the pinion=3.73.thanks again.
rick
Old 03-14-2008, 08:08 AM   #10
slammed1
1972 Chevrolet SWB
slammed1's Avatar
No problem,and I think Im the only one with a 72 with 3.08s.
