computer illiterate
please help me id these casting numbers
engine.. 358180 T0518HCR
intake... 3344459 crank... 1178 Trans... T10-1B, Wg div Q-2 T10-K7 H2-71 thanks keith
72 2wd blazer 72 swb 4x4 |
Dave's not here, man
Re: please help me id these casting numbers
For the engine I got:
T= Tonawanda plant 05= May 18= 18th HCR= 1966 327 275HP 4 bbl Powerglide Rochester carb. Someone please correct me if I'm mistaken. Haven't found anything on the other stuff yet. Also, are you sure the number isn't 3858180?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 03-11-2008 at 05:42 AM. |
computer illiterate
im sorry you are right it is 3858180 i had a dumb ass attack. i double checked all the other numbers listed and they are correct. thanks for what you found so far
Roadtrip!
![]() Join Date: Feb 2003
64-67 327 small journal car or truck.
Intake: How about 3844459? 63-65 cast iron 4 bbl carter afb. My book doesn't break it down anymore.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Chevy One
Mortec list the crank as; 1178.......302.......forged..medium journal...3.00stroke"
Chevy One ![]() 67 1/2 Two-on-the-Floor 67 Nova 2Dr Sedan 03 Monte Carlo I'M NOT OLD, JUST A CLASSIC!!! |
computer illiterate
thats right thanks. lol...........
computer illiterate
i found this for the trans the numbers on it are real close
Dave, What you have is a 1st design Super T-10 which was only available as an over-the-counter complete transmission designed as a direct replacement for the early Corvette T-10. They were made from 1968 through early 1972 and did have 10-spline input and 27-spline outputs like the early T-10 and early Muncies. There were several gearsets available for them including 2.23:1, 2.43:1, 2.64:1 and 3.44:1 first gear ratios. Some even had 9310 nickel inputs (with 0.060" wider gear) and clusters installed (Also had a 0.060" wider front gear to mate with the wider input) which had much higher torque capacity. Later 2nd design ST-10's all had 26-spline input and 32-spline outputs like the 71-74 Muncies. All in all, a good transmission. The only weak point is they have a tendency to seize first gear to the mainshaft. There is no sleeve on the mainshaft for 1st gear like Muncies and ST-10's.
computer illiterate
anyone else? can anyone verify the trans numbers?
computer illiterate
can anyone id this saginaw 4spd for me
gm8281886 3925656 Nfc2 8114
#10 | |
![]() Join Date: Jul 2005
http://www.nastyz28.com/2gcog/trans.html
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 Last edited by larry may; 03-19-2008 at 01:13 AM. |
computer illiterate
cool thanks
