Old 03-11-2008, 04:06 AM   #1
GMC3
custom fuel filler hosea
probably going to mount my fuel filler behind the side marker light or weld in a side door from a later model. question is whatever i do it wont line up with a stock style rubber hose, where do I get the hose to go from my filler neck to the tank? thank you
GMC3 is offline   Reply With Quote
Old 03-11-2008, 05:50 AM   #2
wibilly
wibilly's Avatar
Re: custom fuel filler hosea
i made the majority of mine with muffler pipe and bought a foot of filler hose at o'rielys. it was $17 a foot so plan it well
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-11-2008, 06:18 AM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I'm in the process of doing this. The following mod is done by using a later model (1997+up) S-10 Fuel Neck and same years S-10 gas door for the hinge.
If using the Poly Blazer tank, you should be able to use either driver or passenger side. I am using the driver side marker light. Many board members have refered to Tennmans setup for this modification. He also uses the drivers side. Here is his link for a step by step how-to of this mod. Thanks to board member jorgensensc for posting this:
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
I think your inlet on your tank is 1 1/4 inch and the S-10 fuel neck is 2 inch. Here's how I reduced my Fuel neck. 2 inch reducer to 1 1/2 inch then 1 1/2 inch to 1 1/4 inch Now use 1 1/4 inch fuel line between to tank and fuel neck. Here's a pic of the copper hardware I'm using:
I am not finished yet so I do not have any pics yet. PS That hole in the back of the d/s fender has been filled
Good Luck
Harry
If you have questions, PM your number.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-11-2008, 11:17 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Harry, check to be sure that copper doesn't corrode when using 10% or higher ethanol gasoline. IIRC, it does and could cause problems for you.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-23-2008, 10:43 PM   #5
fishingjred73
fishingjred73's Avatar
[QUOTE=myoldchevytruck;2619801]I'm in the process of doing this. The following mod is done by using a later model (1997+up) S-10 Fuel Neck and same years S-10 gas door for the hinge.
Linky no worky
fishingjred73 is offline   Reply With Quote
Old 03-23-2008, 11:48 PM   #6
myoldchevytruck
Fishingjred,
Try this link on the fuel filler mod
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 03-24-2008, 02:42 AM   #7
fishingjred73
Thanks, much better.
