Old 03-11-2008, 06:46 AM   #1
jlaird
jlaird's Avatar
schrader valve question
So I'm planning my air plumbing and want to put a schrader valve at each bag for emergency situations. I'm wondering where it exactly needs to be located though to be effective. I'm thinking it has to be between a bag and the valves, however wouldn't you need a manual ball valve between the schrader and the electric valves? The reason I ask this is because say for instance a dump valve malfunctions and is stuck open. The bag wouldn't be able to be filled manually unless there is a shutoff in the air line between the schrader valve and electric valves. Follow me? So it would go bag > schrader > ball valve > electric valve.
Second unrelated question: Does the check valve go between the tank and valves?
thanks fellas!
josh
jlaird is offline   Reply With Quote
Old 03-11-2008, 06:52 AM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: schrader valve quesion
Hhhmmm... i just use a shrader valve on my tank to fill it up just in case I would have a problem with the comps. If you dump valve would happen to stick open just smack it with a wrench a few times it will close. LOL For the check valves im not sure I have never ran them
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 03-11-2008, 07:07 AM   #3
SCOTI
SCOTI's Avatar
What about using a piece of line w/the schrader attached but don't install it in the system. If you have a failure, just disconnect the problem line & attach your 'emergency' piece & air it up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-11-2008, 09:44 AM   #4
PrerunnerRob
PrerunnerRob's Avatar
thanks fellas!
josh
question 1
Sounds good, it only take a little bit longer to plumb in the scraeder and isolation valve, the key is doing it the way you stated, and being able to completely isolate the system downstream of the electric valves. This will save alot of headaches IF the electric valves should ever give you problems.
question 2
If i remember correctly, the check valve goes between the compressor and tank, to stop the tank pressure from trying to backfeed through the compressor.
PrerunnerRob is offline   Reply With Quote
Old 03-11-2008, 09:12 PM   #5
jlaird
jlaird's Avatar
Originally Posted by PrerunnerRob View Post
question 2
Yes, this is accomplished by the check valves that come on all Viair compressors.
However, I think you need the check valves between the tank and valves also. With the valves that we use, back pressure keeps them closed. If the tank pressure falls lower than the bag pressure, the bags will deflate if there is no check valve between the bag and tank. This could happen from a compressor failure, pressure switch failure, etc.
I just wanted to verify the above. That's why I asked the question.
Old 03-11-2008, 09:31 PM   #6
bedsled71
bedsled71's Avatar
yep thats what happend to me once.. had to drive about 4 hours at really low speed because my control arms were about an inch off the ground.. sucked
bedsled71 is offline   Reply With Quote
Old 03-11-2008, 09:56 PM   #7
jlaird
jlaird's Avatar
Have you modified your plumbing at all to prevent that from happening? If so, what?
Old 03-12-2008, 03:24 AM   #8
PrerunnerRob
I had totally forgotten about the pressure differential requirements to keep the valve from opening. So you should need a check valve between each fill valve and the tank, in addition to the compresor check valve.
Old 03-12-2008, 11:19 AM   #9
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I have check valves between the compressors and tank and also between the tank and valves, that way if the air leaks out of my tank, it doesn't leak out of my bags. That way when I drain my tank, my hand isn't being squished!
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-12-2008, 06:25 PM   #10
bedsled71
bedsled71's Avatar
what i did was got a check valve between the tank and valves, carry and extra pressure switch and have schrader valves hooked up to T fittings so if i have to, i can put those into the bags
Old 03-12-2008, 08:42 PM   #11
jlaird
jlaird's Avatar
sounds like a plan!
