Gettin By on Gettin By
Well i rewired my 69 CST10 for an internally regulated alternator and now my amp guage is showing amp readings even after the key is off. Looks like i might wind up with dead battery in the morning. I'm sure i missed something. Any idea's. It got dark on me before i could get the ohm meter out.
![]() Join Date: Dec 2003
Re: Amp guage always on after internally regulated rewire
if it's a amp meter then it will stay on.... only volt meters shut off with key... i think... someone correct me if i am wrong.
https://www.ebay.com/itm/295742064443 |
![]() ![]() Join Date: Jul 2002
I think that is correct. I know when you go to the newer style alternator, they say to switch over to a volt meter as the amp meter is pretty much useless.
So the stock guage in the dash cluster i have here is a amp meter?? If so where would i gather up a volt meter??
its all about the +6 inches
where is the needle sitting in the guage?
Was your battery dead in the morning? The amp guage always stays on... period. |
its sitting straight at noon.
didn't have time to check the truck this moning, but i will when i get home. |
that's where it is supposed to be when the engine is off and no load on the battery.
Yup, still there when i got home and battery was fine. Also no melted dash.
Seems i might of actually hooked it up right. Even a blind squarrel finds a nut every once in a while. I'll just have to get used to amps instead of volts on the dash. So it should drop some when running everything and not head to the right more then about 1 oclock?? Thanks for the info. |
The ammeter is in the middle when the key is off and nothing is drawing current from the battery, and when not charging or discharging the battery.
If I remember correctly, it goes to the right when charging, which is fine, and to the left when discharging, which typically isn't good. Last edited by 72lb4x4; 03-12-2008 at 08:35 AM. |
Can Anyoneme Tell How To Wire My Up
