Old 03-11-2008, 07:38 AM   #1
Chevyman680063
Chevyman680063's Avatar
Would you say this is bad?
Here are some pics of some of the rust on the cab of my '63. I know that any rust is bad but what do you guys think about this?
Chevyman680063 is offline   Reply With Quote
Old 03-11-2008, 07:47 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: Would you say this is bad?
EEEEEEWWWWWW!!!! my 60 has 2 rot holes above the windshield along that lip. me thinks bad windshield seals
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-11-2008, 07:52 AM   #3
Chevyman680063
Yeah you could say it's a bad window seal. It looks like I'm also gonna have to have the panel above the windshield on the inside replaced too because I was picking at it last year and found some more rust.
Old 03-11-2008, 09:12 AM   #4
LILRED66
LILRED66's Avatar
This rust occurs primarily because of the seam seal at the drip rail around the top of the cab perimeter. Check there first to ensure it is sealed up good. You will need to remove the winshield, repair and rust-proof the damage and install a new windshield gasket. When the water gets into the cavity above the windshield it will run along the top to the "A" pillars and down along the seam above the dash and down into to the kick panels and lower "A" pillars, leaving rust along the way.
LILRED66 is offline   Reply With Quote
Old 03-11-2008, 09:27 AM   #5
Chevyman680063
That's more than likely why the piece above the windshield has rusted. The piece on the right side below the windshield is because of the hole in the seal as you can see from the picture. I know it's going to cost me alot to get those two spots of rust fixed.
