Keep Your Nose Clean
How much SHOULD it cost?
Greetings folks, I'm getting ready to have the rear end housing reassembled. How much is a reasonable amount to pay to have this done? It is all apart right now because I had it powder coated. It is a 12 bolt posi with drum brakes. Anything can help at this point. Thanks.
LAIDOUT
Re: How much SHOULD it cost?
So you need the gears set and lashed then? I wonder what that costs as well. The machine shop here will shorten rear ends but won't do gear setup...
A good builder around here charges around $250 if your using brand new gears.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 03-14-2008 at 08:59 PM. |
here too...anywhere from 200-300,with your parts
I just payed $240 to have my limited slip installed and a gear swap with all new bearings and seals.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop |
