Old 03-11-2008, 11:36 PM   #1
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Question Squeaking somewhere in the steering???
So, I am not exactly sure what is going on, but when I turn the wheel when I'm going slow, or not moving something squeaks pretty loud, and it gets hard to turn the wheel. It didn't do it before, but it was kind of sitting for just a little while. Anyone have any ideas? Can't figure it out, wether its a belt, low on P.S. fluid? Not as proficient with suspension and steering as I should be.
Even if its just an idea, post a reply. If noone is sure I would like to make a "checklist" anyways.
Thanks in advance,
Jared
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 03-11-2008, 11:58 PM   #2
slash crashley
lucky knuckles
slash crashley's Avatar
Lightbulb 3 cheers for white lithium grease.
i had a constant squeak in my honda civic with a grant after market wheel. (armstrong steering) i happened to pick up some lithium grease for my trans linkage and put a squirt in the hub housing area of the steering wheel. it cured it immediately and hasn't made the slightest squeak since.
eventually all moving parts get dried out or get a build-up of crud in there. give it blast with lithium grease and see if it helps.
slash crashley is offline   Reply With Quote
Old 03-12-2008, 01:53 AM   #3
SRH916
SRH916's Avatar
Re: Squeaking somewhere in the steering???
Oh, the squeaking is somewhere outside the cab. Only things I could think is somewhere in the steering pump, belts, or something else out there. I really am not sure though.
Thanks,
Jared
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 03-12-2008, 04:41 AM   #4
1984Silverado4x4
My brothers truck had a loud squeaking noise but it would squeal constantly while you were driving it and if you were sitting still it was very hard to turn the wheel.
We put a new belt on and it worked perfect
Its no disgrace being poor. Its just inconvenient.
1984Silverado4x4 is offline   Reply With Quote
Old 03-12-2008, 04:48 AM   #5
SRH916
SRH916's Avatar
Thanks, I will go check the belts soon.
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 03-12-2008, 10:42 AM   #6
89 crew
The only other options I can think of is dry tie rods, and ball joints, but they wouldn't be very loud. If it happened only when moving it could be wheel bearings. A belt is the most likely problem based on description.
89 crew is offline   Reply With Quote
Old 03-12-2008, 09:04 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
belt check the fluid level and if all else fails get a buddy to turn the wheel while you isloate it it could be the pump gone bad too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-12-2008, 09:28 PM   #8
SRH916
SRH916's Avatar
Unhappy Re: Squeaking somewhere in the steering???
found the "problem"... my friend is a dumb*** he completely removed the bolt that holds my power steering pump in place... so now I can't get the bolt back in... I hope its not stripped Any tips to getting these bolts back in. Chevy seems to be notorious for this Well, I have to try to get the bolt back in when I get home... I was working at it for about an hour yesterday :\ Any tips?
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 03-12-2008, 09:33 PM   #9
86 GMG
Loosen Other Mounting Bolts And Try To Insert The Bolt Not In It Know It May Just Need A Little Play To Go In Square Good Luck
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 03-12-2008, 09:38 PM   #10
SRH916
SRH916's Avatar
it goes in really crooked, I think my friend may have stripped it trying to force it
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 03-13-2008, 06:02 AM   #11
old Rusty C10
well then retap the bolt
Bob
I hate cancer!!
Old 03-13-2008, 10:48 AM   #12
SRH916
SRH916's Avatar
Can I use a helicoil kit?
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 03-13-2008, 11:42 AM   #13
Russell
Professional Grade
Russell's Avatar
Yep, that'd work very nicely
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-13-2008, 01:03 PM   #14
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
When you loosened up the pump to try and get the bolt back in, did you take the belt off? If not, that'll make it ten times harder to get the bolt back in.
Get the bolt in, then reposition the pump so you can put the belt back on, tension the belt, then tighten all the bolts back up.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
