Old 03-12-2008, 01:15 AM   #1
6bangr
Talking Fast Drop
whats the quikest way to drop my 69 c10from the front and rear.
From the front end it looks like i can just cut down the springs, but the rear end looks tricky though. How do i mess with that. Im just looking for something temporary cause she's just sittin their for now. at least she'll sit prettier.
6bangr is offline   Reply With Quote
Old 03-12-2008, 03:02 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Fast Drop
cut 1 full ring off the bottom of the front coil (2 1/2" drop), & use a 2 " block on the rear (tween the diff & trailing arms). that will be the quickest/cheapest drop....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-12-2008, 04:02 AM   #3
andrewt2
andrewt2's Avatar
Re: Fast Drop
If it has Coil Springs all the way around you COULD just take a torch and heat each spring til it sags low... not a way id ever do it.... but i did back when i was in highschool and was poor and couldnt afford to do it right.... the ride quality SUCKS and its just not a real good idea...
andrewt2 is offline   Reply With Quote
Old 03-12-2008, 05:01 AM   #4
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Fast Drop
If you fit drop springs front and rear do you then need to change the shocks??
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-12-2008, 05:12 AM   #5
andrewt2
andrewt2's Avatar
Re: Fast Drop
depends on how much of a drop you do but it wouldnt hurt. shocks are usually inexpensive enough.
Old 03-12-2008, 07:03 AM   #6
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Arrow Re: Fast Drop
1.) Cut coils up front only!
2.) 2' lowering blocks out back.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-12-2008, 07:07 AM   #7
Shane
Shane's Avatar
Re: Fast Drop
cut one round off front coils and use late 60's - early 70's Chevelle / Nova / Malibu springs in the rear ... cheap and low
Shane is offline   Reply With Quote
Old 03-12-2008, 02:11 PM   #8
eightbanger
454 MAKES IT ROAR
Question Re: Fast Drop
OK we have had a few good suggestions for a fast and cheap drop heating the springs up to collapse them being cheapest and fastest, thats what had been done to mine by the previous owner and it does handle like a pig.
But man I get confussed with all this stuff drop springs, drop spindals lowering blocks..
Example:
Should you use drop coils with drop spindals or should they be used seperatly?
If you use drop coils does this mean you don't need drop spindals? Does drop spindals override the need to fit drop coils?
When do you use lowering blocks?
Do you use lowering blocks instead of drop coils or with the coils?
Or are the many combinations just down to personal choice?
Lets say I want a level look front to back were the bottoms of the wheel arches meat the tops of the tires, what would I need to fit?
Nigel.
No more pain.
Old 03-12-2008, 04:44 PM   #9
andrewt2
andrewt2's Avatar
Re: Fast Drop
It's really not that hard just figure out how low you want your truck to sit... im going with a 3/4 drop on my truck, im achieving this with new springs all the way around. i was lucky enough to find new front and rear springs on the site for slightly less than retail and for about 250 bucks after i buy my new shocks i will have achieved the stance i want... but say your using drop spindles up front. i believe you can get them in a 1.5 lowering or a 2 inch lowering configuration. say you want a 4/5 drop you would use 2 inch drop spindles up front and 2 inch lowering springs to achieve your 4 inches of drop on the front.. then on the rear. im not sure if they make 5 inch rear drop springs but someone correct me if im wrong but you would use 4 inch lower springs on the rear with a 1 inch block.... make any better since?
Old 03-12-2008, 10:58 PM   #10
eightbanger
454 MAKES IT ROAR
Re: Fast Drop
But what do spindals do that springs don't and vice versa?
Thanks for explaining andrewt2
Nigel.
No more pain.
Old 03-12-2008, 11:02 PM   #11
andrewt2
andrewt2's Avatar
Re: Fast Drop
You know. im not real sure.... i imagine a lot of people wanting to go with drop spindles opt to go that route so they can piece together a disc brake front end.... but maybe someone can help me out here.... any advantages or disadvantages to one over another?
Old 03-12-2008, 11:11 PM   #12
Shane
Shane's Avatar
Re: Fast Drop
You can only go so far with either ... 2 /12" - 3" MAX on spindles OR approx 3" on springs before you start running into problems with scrubbing or with alignment issues. BUT, if you combine 2 1/2" drop spindles WITH 2 1/2" drop springs, you now have 5" of drop and can still align with minimum problems and not worry about anything hanging below the "scrub line/"
Hope this helps.
Old 03-12-2008, 11:18 PM   #13
6bangr
Re: Fast Drop
Hell yes !
Old 03-12-2008, 11:26 PM   #14
RoadRacer
Tire Shredder Extraordinaire
RoadRacer's Avatar
Re: Fast Drop
I have a combo 2 1/2" spindle drop and a 2" spring drop; the main thing you have to be aware of with the spindle drop is that your wheel backspacing doesn't become an issue with the inside rim of the wheel hitting the edge of the lower control arm at the left/right steering limits.
RoadRacer is offline   Reply With Quote
