tv cable length 700r4
I want to install a 700r4 behind my 350 engine with an edelbrock carb.
Before i do this i am gathering all the parts needed. Now i have two questions. First, what would be the length of the tv cable i need. I have looked everywhere but i can't find any answers on that, there are many different lengths. Second, what type of transmission mount is best to use. I am making my own crossmember. thanks
Anybody can restore a classic, takes a man to cut one up..... http://www.arnoldscustoms.com |
instagram "footbraker67"
Re: tv cable length 700r4
The best thing that has worked for me was a stock TV cable that can be found at any dealership. They are meant for the trans and easy to adjust. I tried an aftermarket universal one and it never wanted to stay adjusted right. hope this helps, cant really see it in the pic but it was the closest thing i had, sorry
My idea is indeed to order a stock cable but there are so many different lengths.
I need some more parts from rockauto so that is where i would like to order the cable.
Back in the sticks
Not sure of the lenth, but it should be about the same as the TH350. I know last time I got one, they had to give me a corvette one, but I don't know the length.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Long Fleet Club
If you are making a parts list add this TCIŽ 700R4 Constant Pressure Valve Body it will keep you from having low pressure from having the TV cable slightly off
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
Back in the sticks
![]() Also would suggest you get the tranny shop to set it up for you so you don't blow it up. Don't ask me how I know this.... ![]()
You can got the constant pressure valve body route or get a TV system from bowtie overdrives. It includes the linkages for the side of your edelbrock carb and keeps the geometry correct. The length of TV cable is not that important as long as it is not stretched at all and doesn't have so much slack that it gets in the way of any moving parts. My truck's PO rigged up some home made crap and it never worked right because the geometry was wrong. There has to be the right amount of cable pulled out at the right time to make it work right. These things can go south in a hurry if they are wrong but if they are set up right it will make driving these trucks so much better.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
![]() Join Date: Nov 2004
Bowtie Overdrives kit works well.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
I have found a site that has exact geometry for the bracket on the carb.
That wont be a problem to make. I have seen the bowtie overdriver kits and they are verry nice. Only the price is not that nice, that is why i want to make my own bracket. I think i will order a 39 inch long cable. My other project needs to much money. http://home.planet.nl/~sand1534/albu...od/index4.html
Long Fleet Club
With the TCI kit you don't have to go through all the trouble in trying to set the cable just right to keep it from messing up the trans. The valve body makes it to where the only thing the TV cable is for is to adjust the shift points. The bowtie overdrives kit keeps it where the TV cable adjusts the shift points and what pressure the transmission is at.
