Lift for 72 C10 2 Wheel Drive?
Hello All,
I have a 72 c10 2 wheel drive and would like to raise it so that I can run 31" tires. I do not care for body lifts and would like to do this all suspension. It is currently lowered with CPP spindles and springs. I have the rear coil suspension. Any suggestions? A quick search of the internet and this board gave me no results. Thanks, Scott |
Rottenwood Garage Member
Re: Lift for 72 C10 2 Wheel Drive?
Several companies make coil lift springs....about 2" springs should do it but that is about as far as you can go and still allign it.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
I appreciate the response. Do you have the names of any of those companies?
Scott |
![]() Join Date: Apr 2004
I would sell it and buy a 4x4. There are much easier to lift with leaf springs.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Junior Member
Fabtech used to sell lifted spindles, springs and upper ball joint spacers for 73-87 trucks which worked on our trucks, but sad to say they no longer carry these. Your best bet would be to get a spring shop to build you a new spring with the lift you need (2 - 2.5" max). The upper ball joint spacer would also help alignment if you could have a machine shop mill a 2" billet spacer to fit between the ball joint and control arm.
i have 31"tires on my 69 stock height plenty of clearance
common sense isn't so common anymore Last edited by wibilly; 03-12-2008 at 06:34 AM. |
Just loves his truck.
im getting ready to put 31s on my truck all i did was get rims with a shorter back spacing and wider too...
![]() ![]() EAGLE SCOUT FTW!!! |
I am running 31's stock height....heres my combo...31x10.50r15LT
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
i KNOW for sure i have at least 31's (PO installed them, im not a fan) and they might even be 33s, i do remember them being the same size as my buddy 79 4x4. stock height, no clearence issues.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Junior Member
My stock '71 C-10 has 30x9.5x15 on the front and the rear has 31x10.5x15.
Danny |
Junior Member
stock height and running 31's on my 69
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
spring spacers?...OOO you could do wheel spacers check ebay
