Old 03-12-2008, 03:46 AM   #1
ron350
ron350's Avatar
Glove box hinge repair?
I am looking to an alternative glove box hinge repair for my 75 C10.
So far I have not been able to find a 6” long piano hinge to replace the broken plastic hinge.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 03-12-2008, 07:35 AM   #2
kevinr1970
Re: Glove box hinge repair?
If you are talking about just any old hinge, I could send you one of the hinges we use at work?
They are steel (maybe stainless but I doubt it) and 6" long.
I would send one to you if you thought it might work?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-12-2008, 08:01 AM   #3
bigblock73
yeller
bigblock73's Avatar
Why not get a new glove box liner from a local wrecking yard? That will solve your problem...the "GM" way.
bigblock73 is offline   Reply With Quote
Old 03-12-2008, 08:21 AM   #4
ron350
ron350's Avatar
Woops that was supposed to say 16” long piano hinge.
I can not believe Chevy would make such a cheap glove box hinge.
The way the mounting holes are at different distances from the hinge point makes it harder to find a replacement metal hinge. Guess I will have to look at the salvage yard.
Old 03-12-2008, 07:54 PM   #5
slepysal
slepysal's Avatar
I just picked one up at a local yard for 4.00 easy fix, but I agree very cheep hinge set up
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-12-2008, 08:08 PM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Yeah it's a crappy design but I've always found good ones at the junk yard.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-13-2008, 08:31 AM   #7
lurch115
lurch115's Avatar
junkyard is going to be about the cheapest and easiest fix! i think i have a couple glove boxes on hand just in case... but seeing as how i am retiring the '84 4X4 this spring i highly doubt i will be needing them anymore since the 2wd shortbox is in "like new" shape
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-14-2008, 07:41 AM   #8
ron350
ron350's Avatar
Shoot I just realized that the factory build sticker is in the glove box.
Oh well off to look for more brass hinges or black plastic.
