Old 10-27-2002, 01:33 AM   #1
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
How to tell if a frame is bent?
My bed leans to the passenger side at the rear, but it's flat(ter) in the front. It really started bothering me lately, so I figured I'd take the bed off and remount it. Looking underneath it.. all the bolts were tight, nothing loose or missing. The only reason I thought bed bolts was that it also felt very "loose".. the bed feels like it's hopping when you go over a bump.
So now I have no clue why it leans to one side. The bed itself is straight, as far as I can tell. The rear end of the trailing arms both sit the same distance from the ground. The coils measure within 1/4" of each other. The fact still remains that, measuring from the outside lip of the rear wheel well to the ground, the passenger side sits at 33 3/4", and the driver's side sits at 35".
So, I guess the only thing left is for the frame to be bent, huh? Is there anyway I can check for this? The frame isn't visibly tweaked/bent/wrinkled at any certain point, to my untrained eye anyway.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 10-27-2002, 02:20 AM   #2
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
you could hang a plumb bob from each frame corner and measure. you'd have to have the same psi in all your tire to get an accurate measurment so i'm not sur how well that'd work. that's my only idea. hope it helps.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 10-27-2002, 11:30 AM   #3
Hutch
Hutch's Avatar
Maybe the mounting pads (rubber)or bed frame stands (on the frame rails are crushed.
For a test put some spacers under the bed mounts on one side.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-27-2002, 04:48 PM   #4
neonlarry
neonlarry's Avatar
I talked to someone that remembered their dad buying a brand new 69 GMC, and the first thing he did when he brought it home was put 1/2 inch spacers under the bed on one side so it would sit level. I am not sure, but maybe some of them were just made crooked?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-27-2002, 05:22 PM   #5
mikep
Used to have a truck
mikep's Avatar
When I bought my truck it leaned to one side like that. Couldnt figure out why. It had a receiver hitch that was welded to the frame along with the step bumper that was on the truck. When I cut the bumper and hitch away from the frame to put the new bumper on it made a loud noise. After that it sat level. I figure the receiver hitch was welded on while it was on a lift and it loaded the frame to sit high on one side. Might have been like that for 20 years or more.
No truck :-(
mikep is offline   Reply With Quote
Old 10-27-2002, 07:08 PM   #6
Patrick Sullivan
Hahah, mine is welded the same exact way. Maybe I'll grind the hitch and bumper off (been meaning to anyway) and see if it gets me anywhere. If not.. I guess I can shim the bed around a bit. Thanks guys.
Old 10-27-2002, 07:59 PM   #7
crazy longhorn
Fabricate till you "puke"
It could be the same guy welded both hitches . you might also try swappin the springs side for side, & see if that makes a difference. Some times a measure at the frame rails can be deceiving, as that is roughly a 3' span, & to measure the wheel lips you are workin with more like a 6' span.......if a spring is weak it will lay one side over, & the other side may be up a bit. if you had the box off, &6' layed a straight edge across the frame, it would be very clear that the distances would change from the center point to either end.....more drastically the farther you measure out........crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-27-2002, 09:17 PM   #8
sbrban
To measure your frame you would need to take the susp. out of the measurement.Put floor jacks at 4 corners of the frame- all of same height-2 under frame at front cab mounts and 2 at rear of cab(or a little farther) in same spots.let susp. hang then measure side to side to see any major differences-there's gonna be a little,after all it is 30 years old. If its close there then you've eliminated the frame.
you never have too many suburbans....
sbrban is offline   Reply With Quote
