03-12-2008, 04:48 AM | #1 |
single stage paint pics
lets see some pics of single stage paint jobs!
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
03-12-2008, 05:24 AM | #2 |
Re: single stage paint pics
Ok ok ok...its not a truck but dont shoot me please... this is a single stage jobber.... was our first done at home... you can notice how going panel to panel we did not over lap and the paint built up at the edges of the panels.. but i only had 85 dollars in supplys on that job and all and all when its crusing down the highway it looks real good!
03-12-2008, 05:55 AM | #3 |
LAIDOUT
Single stage PPG DCC GM Torch Red, shot at home;
03-12-2008, 06:17 AM | #4 |
great thread....keep em coming
03-12-2008, 07:06 AM | #5 |
DuPont single stage Centuri (sp?) for the green metallic. The white (bumper and cab roof) are PPG Omni MAE also a single stage paint. Both are painted over the PPG Omni epoxy primer that was sprayed on over bare metal.
I only got as far back as the doors. When the bed and last 3 inches of cab are done I'll post pictures other than of just the front of the truck.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
03-12-2008, 07:10 AM | #6 |
03-12-2008, 07:13 AM | #7 |
I might be wrong but that pic looks as if he's in the color sanding stage in which case its probably just paint dust on the wheels? im not sure i know anyone that would spend the kind of money those rims cost then not take AMPLE amounts of time to tape them off before paint... either way extrodinary paint job and i really like his build!
03-12-2008, 07:22 AM | #8 |
wow!!! is that just sprayed, or is it wet sanded and cut and buffed?
03-12-2008, 07:28 AM | #9 |
I believe this is PPG Omni. Sprayed it myself in my workshop with a $25 spray gun. For my first try at paint & body I'm very pleased with my results.
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
03-12-2008, 08:44 AM | #10 |
I have a radical idea!
My '69 has single polyurethane enamel, and was painted about 17 years ago. The pics are recent, and it still realkly shines, but this bad boy was beautiful when the PO had it painted originally. I can't believe he didn't keep in out of the weather after the restoration.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-12-2008, 09:17 AM | #11 |
TILT COLUMN GURU
Dupont Chroma one painted April 1998. Still looks like it was shot yesterday.
03-12-2008, 11:04 AM | #12 | ||
LAIDOUT
This shot is before buffing, its got a few bugs and some peel that I had to sand out; |
03-12-2008, 11:17 AM | #13 |
looks awesome guys...
-wes |
03-12-2008, 02:37 PM | #14 | |
03-12-2008, 04:11 PM | #15 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-12-2008, 04:54 PM | #16 |
The green sure is. I took the paint code to my DuPont jobber and had him mix it up. The sheet metal (when I started, some has been replaced) was from a 1970. The paint code is something like "medium green poly". The poly being what we would call today metal flake. Inside the green cab, it is tough to tell the difference from what is original and what came out of my DuPont can.
The white is NOT the original white. The original white I think is a tad more ivory or off white than what I have.
03-12-2008, 05:31 PM | #17 |
Med. Metallic Blue Urethane.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-12-2008, 06:19 PM | #18 |
Painted in the early 90's
03-12-2008, 07:42 PM | #19 |
db_FM08__163 single stage ppg doors only buffed part on truck
03-12-2008, 08:56 PM | #20 |
I hate to sound like a total newb here, but can you explain what you mean by single stage. What are the other options? I know nothing about paint.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
03-12-2008, 09:00 PM | #21 |
Single stage is just that. It's kind of like spray paint, but with a real paint gun. You spray it all in one shot and you're done. You mix the paint, hardener, and reducer all at once, spray, and that's it. You can do as many coats as you like.
Two stage is your base/clear option. You spray on your paint color, (base coat) and once that flashes you can spray on your clear coats. This is how new cars are painted.
03-12-2008, 09:08 PM | #22 |
Skinned knuckles
You beat me to it 67ChevyRedneck..
Here's a '72 that I painted several years ago with single stage. This was after I cut and buffed it. And for comparison, here's a base coat/clear coat I did on another one I "should have kept".
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 Last edited by Blue'72; 03-12-2008 at 09:09 PM. |
03-12-2008, 09:09 PM | #23 |
OK. Thanks for the info 67ChevyRedneck. BTW, I've got a brother in your neck of the woods. Spartanburg. Nice truck.
03-14-2008, 04:06 AM | #24 |
how many coats are you guys spraying, and alo how much wet sanding and buffing are you doing??
i just got single stage orange paint for my truck
03-14-2008, 08:20 AM | #25 |
The blue mustang of mine we laid 4 coats and didnt wet sand or buff anything except the hood... would have turned out a lot better if we would have...
