03-12-2008, 08:37 PM | #1 |
Show your homemade tools
I'm a little embarrassed showing these in light of the talent we have on this board, but if you're like me, sometimes you don't have the right tool to do the job. So what do you do? Go caveman and make your own!
Example1: I found it difficult to set the rivets when I rebuilt my wing windows so I got a $1.00 Harbor Fright chisel and notched and welded the setting tool to the end. This allowed me to swing the hammer safely above the frame of window. Example 2: I ground a cheap 17MM socket and fashioned a crude spanner to work with the switch bezels. Example:3 The most shameful of all , I hammered a piece of coat hanger to fit in the electrical terminals to release them from their case. I know it's not much but I pretty sure these separate me from lower forms of life.
1972 K-10 SWB Cheyenne Last edited by nyncompute; 03-12-2008 at 08:38 PM. |
03-12-2008, 08:49 PM | #2 |
is Certifiable
Re: Show your homemade tools
I have a few at home I made when I was in highschool. Also a few that my dad made (around the same time). I will post pics tonight.
03-12-2008, 08:57 PM | #3 |
Skinned knuckles
This was the prototype. The finished "tool" didn't work much better, but with a little more creative ingenuity I think it would be handy.
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
03-12-2008, 09:38 PM | #4 | |
Here's my custom header spark plug socket. Best $1 ever spent at Advance auto parts. Make sure to buy the cheap socket found at the register, the metal isn't as hard to cut. |
03-12-2008, 09:43 PM | #5 |
Gettin By on Gettin By
Like the eletric tooth brush there.
03-12-2008, 09:51 PM | #6 |
Skinned knuckles
I was wondering what was up with that spark plug socket until I saw the picture in use. That's a cool idea!
The electric "tooth" brush was supposed to be for the hard to reach areas inside the frame rails. If I had a dog gone blade that didn't wobble back and forth so much, I think it would have worked.. It did help using heavy duty wire ties to keep the brush from flying off...
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 Last edited by Blue'72; 03-12-2008 at 09:52 PM. |
03-12-2008, 11:01 PM | #7 | |
Yeah, if you look at my spark plug inside the head, you can see there's no way to tighten them with a wrench. So, I either needed to make this tool, or buy a real headersocket for $40, or buy shorty plugs. I have that socket in a very special place now, so I'm sure it doesn't get lost. |
03-13-2008, 12:50 AM | #8 |
is Certifiable
Here are a bunch.
First off is the SBC oil pump pick up tube installer. Makes it easier to tap it in. Another view Second are these plates I made to pressure test the coolant passages when an engine is assembled. I have a bunch of plates and rubber gaskets. Another view Next is a tool for carrying SBC heads easily. Just screws into spark plug hole. This one is to prime an engine with oil before start up. Take dizzy out and clamp this in place. Run it with a drill. Just an old SBC push rod squished on one end, and a mounting peice made by my father. Next 2 pics are a special socket made to slide on the end of the crankshaft. I use this when assembling the engine. Using a beam type torque wrench you can check the amount of pressure needed to turn the crank over. Makes it easy to spot a problem before you get too far into the assembly. Another view This last tool is a cam bearing installer. The top part goes in the end of the shaft, this is what you hit with the hammer. The second piece slides in the bearing. Wrap it one time with masking tape to protect the bearing. The bottom one, is keeps everything centered. Only thing not pictured is the metal tube. Kind of a long post, but there are my homemade tools. Only thing not shown is a finger of a leather glove I cut off. I put this over the open end wrench when I am working with batteries, and stuff. A little security, so I don't worry about banging it on something and arc welding it haha. |
03-13-2008, 05:43 AM | #9 |
Just what I was afraid of. That engine rebuiling stuff makes my "innovations" look prehistoric.
1972 K-10 SWB Cheyenne |
03-13-2008, 06:18 AM | #10 |
is Certifiable
Nonsense. I was looking at that socket you made thinking........damn I wish I had that last week haha.
03-13-2008, 06:31 AM | #11 |
i have a pretty sweet slidehammer with vicegrips on one end my dad made... i use it all the time
and on the oil priming tools you have to have the distributer body on there if you want oil pressure to both sides of the motor... i'll have to get some pics of mine |
03-13-2008, 06:41 AM | #12 |
Truck and auto performance nut
....nobody has patents on any of these tools yet,
do they???
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-13-2008, 06:51 AM | #13 |
Hand Crafted C-10
Being less than tall, I climb in and sit in the engine bay often. It didn't take too many reminders to ram a chunk of styrofoam down over the hood catch!
03-13-2008, 07:23 AM | #14 |
This may be a funny time and place but tools often come in handy when you never expected them to. Yesterday my kitchen sink handle broke off of post and I have not had a chance to get to hardware store. My trusty old tool box provided a deep 5 MM and extension to get the dishes done. Maybe a little Home Improvement coming soon.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched Last edited by DavesRide; 03-13-2008 at 07:25 AM. Reason: a little comment |
03-13-2008, 07:27 AM | #15 |
sheshhhhhh, you're all professional like...those tools dont look to ghetto at all...
03-13-2008, 07:28 AM | #16 | |
03-13-2008, 09:12 AM | #17 |
Been hanging light in my shop made a tool to make location and modified a tool to install hangers in the joists
A little grinding and some tape and I was in business !
"I feel the need for speed!"... as soon as I am done with my nap. |
03-14-2008, 10:09 PM | #18 |
#16876
I'm no genius inventor. I did although make a couple items.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
03-14-2008, 11:28 PM | #19 |
What kind of headers are those?
B |
03-14-2008, 11:45 PM | #20 |
It's a catastrophic success.
These are some bigger things I made because I needed them, A press and engine stand.I also have a engine hoist.
03-15-2008, 03:13 AM | #21 |
03-15-2008, 03:25 AM | #22 |
Heres my test light that buzzes instead of a light. Handy for tail lite work & such...
03-15-2008, 03:48 AM | #23 |
I will answer for Jim as I know (I kept pinging him on his exhuast). They are Doug Thorly Tri'y's. No idea on the part number, but he has thread on the exhaust install.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
03-15-2008, 03:56 AM | #24 | |
Thanks, didn't see that... yeah, I'm not done with it enough to post any pics of the Magnaflow system, I kinda got caught up in some body work. |
03-15-2008, 04:01 AM | #25 |
