changing 2 speed to delay wipers
I have the 2 speed wipers in my 79 and i was wondering if i could swap in the steering column with delay from my 86? do i need to change wiper motors or can i just wire the delay to the old motor?
thanks
79 GMC Sierra 5.9 cummins, nv4500 Last edited by 79GMC_OLDS; 03-12-2008 at 09:27 PM. Reason: typo |
![]() Join Date: Mar 2006
Re: changing 2 speed to delay wipers
Im not sure about the column swap but why dont you just buy an intermittent wiper switch/relay from the junkyard. It works great and plugs right in to the 2 spd. wiring plug. There is one on EBAY right now.
1986 C10 - LWB, 305/700r4, posi, vortec heads Last edited by BowTieOgre; 03-12-2008 at 11:06 PM. |
#3 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
I've got the switch and module on my 81 crew. I'll get pics of it tonight and post them on here so's you can see what the connections look like. If they are the same as your '7 model then they should work. Otherwise you'd have to do a slice-n-splice.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
ok awesome thanks...so if i wanted column mounted controls i could just wire the delay into the original wiper motor? in other words the motor has nothing to do with the delay
79 GMC Sierra 5.9 cummins, nv4500 |
Yeah the delay part is handled by a part that goes between the switch and the factory plug...nothing to do with the motor.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
#7 | |
Sorry for the multiple posts mods.
1986 C10 - LWB, 305/700r4, posi, vortec heads Last edited by BowTieOgre; 03-13-2008 at 06:07 PM. |
Actually...the 77 and down wiper motors are quite different from the 78-83 motors. I tried to put a 78-83 motor on a 77 and it wouldn't work. The connectors don't match up, and there aren't even enough wires. Same on the switch side, the 77 connector is incompatible with the 78-83 switch.
In order to perform the swap, I had to remove all the wiring from the 78 and transfer it to the fuse box of the 77. Also had to enlarge the switch hole in the dash and drill new mounting holes. Last edited by Pyrotechnic; 03-13-2008 at 05:27 PM. |
This guy put delay wipers in his 75 Burban and has some great info:
http://www.rowand.net/Shop/Tech/DelayWipers.htm
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
