Old 10-27-2002, 11:07 AM   #1
CustomMike
engine identification
Can someone identify this engine. The number on the engine is T0107HCR. I have tried matching it up to nastyz28 but I had no luck.
CustomMike is offline   Reply With Quote
Old 10-27-2002, 11:17 AM   #2
Hutch
Hutch's Avatar
Not sure about that number.
There should be a number on the back drivers side ledge on the surface where the head meets the block probably begins with 39 then some other numbers.
Small block,Big block,inline 6. v/6?
Whay year model truck?
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-27-2002, 11:37 AM   #3
68 Stepside
huh?
68 Stepside's Avatar
Well, I'll give some of it a shot
T= Tonawanda (the factory where it was built)
01= January
07= 7th day of the month
and the only thing I can find that remotely fits the letter code are the following:
HR= 350, 3 spd manual transmission
HC= 350, 2 bbl carb
I don't know if that's even close to correct, as far as the letter code goes, maybe someone else will be able to help.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-27-2002, 02:19 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
most likely 1969 350 engine if is HC or HR
Fast68Chevy is offline   Reply With Quote
Old 10-27-2002, 09:45 PM   #5
CustomMike
The engine is a v8 in a 1970. I may have to look at it again to make sure I got the number correct. This is a truck that would likely be good for parts only. I want a 350. The data plate indicates that it is but who knows if it has been switched. I know it has been converted to a automatic.
