cab floor update
just thought I would post a few more pics of my progress, I feel like I'm doing a better job on driver side since I was broke in on passenger side. A little time and you start figuring out better and easier ways to do things
Added today's progress can tell a little better. Am I doing this right you guys gotta tell me, it's what I think should be done. Last edited by truckn'; 03-14-2008 at 12:51 AM. Reason: adding a few more pics |
1961 crewcab
Re: cab floor update
looking good, flintstones no more!!!
Did you just plop that onto the old floor and weld it in or are you gonna cut out the old floor?
had already cut old floor out haven't finished cutting and put in at foot well, tacking it so I don't miss calculate.
YABADABA OOOOOOOOO MEAN !!!!!
why????? why????? ![]() ![]() ![]()
1966 chevy c-20 truck " La Chata " under construccion ![]() ![]() ![]() |
Looks nice, good work. I know what you mean, do one side the other gets done faster and better!!
Hey Y'all!!
Makin some nice progress. Keep up the great work!
I updated the pics they are a little better
TexasBowhunter
Looks good!
I have a question for you. I am about to do the same thing to my son's 66. His outer rocker panels are in great shape, but the part that the weather stripping attaches on the bottom is rusted out. Would this piece be called the "inner rocker panel"? Or should I just get the whole rocker panel, like you did? Keep up the good work! |
#10 | |
It part of the rocker panel. |
the weather stripping connects to the top lip of the outer rocker panel.
UCA63
Like Joey said ????
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#13 |
Tot Roddin'
Lookin good!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#14 |
1961 crewcab
It is part of the outer rocker, if the rest of the rocker is fine , I would just bend a piece of sheetmetal at a 90, trim it to fit and splice it in.
there are spot welds along the rocker right there, you can use a piece of sandpaper to find them. the spot that yuu would be working in is right where the outer rocker is welded to the inner rocker. |
#15 |
Jon and David are right, both the inner and outer rocker panels were shot, I haven't put the outers on yet have to replace A pillars and cab corners first. replacement is difficult just drill spot welds remove, fit and cut to fit and weld back into place. I'll post a pic of passenger side with outer rocker set in place just to check fit.
#16 |
trust me, I'm an amatuer compared to most of these guys and if I can do it anyone can
#17 |
Who did you buy you repair panels from. I'm about to do the same and I've heard that some of the panels out there aren't as good as others.
#18 |
I bought my panels from LMC, I can't say that they were an exact fit, but close enough where I could get things lined up. I tried to purchase from Tabco, they were behind and it took a few months for them to answer me. I didn't have the time to wait so I got them from LMC. I have heard Tabco is makes a much better part but I can't prove it. I have several other pieces I need guess I'm gonna go for price and make it work regardless. You know I may be wrong but these patch panels aren't meant to just plop in place because most of the time the rust doesn't go that far, so some cutting and grinding should be expected when replacing.
#19 |
1961 crewcab
I think tabco is USA, and just bare metal, the others that are black are tiwan.
When I worked for golden state pickup parts,we nsold both versions, and for the most part did not have complaints about either. |
#20 |
Kissing, There are usually (at least around DFW), several swap meets where you can get the parts at a discount, and not pay shipping. Check the local papers in the antique/classic classified area.
Classic parts is Ok City classiccheveroletparts.com is one of the closer out of state (no sales tax) parts suppliers... |
