Column Shift Problems/anyone ran into this?
I got the column shift in my c10 but everytime I drive it after the first shift the teeth in the shifting mechanism(does someone know what its really called?) gets all intwined. either it doesnt go into gear or from a stop goes into reverse after a few good jams.
Do I need a new shifting mechanism? Can I rebuild the one it already has?,or should I put the floor shift? has any one ran into this. |
Under Construction
Re: Column Shift Problems/anyone ran into this?
this a 3 speed on the column? u mentioned after a few jams so sound like a standard to me... if so if the clutch etc. adjusted correctly.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Chevy Guy
My 71 C10 had a real issue with the linkage....worn out, jamming, etc.
I've put a floor shifter in it for the moment until I figure out all the details on swapping in a T5. It's a Mr Gasket 'one size fits all but really doesn't' from Autozone. Had to download the instructions from the web site and did a lot of modification to get it to fit. Normal hand tool work, grinding, etc. Works great but the shift pattern is 'flipped' from what I expected. No problem. It's now a pleasure to drive. Bypass that column linkage with a floor shift and I think you'll find your problems reduced if not eliminated. Regards.
Juergen Juergen and Ana's Web Page '54 Belair '57 Townsman 210 '67 Malibu Vert '71 C10 '96 Vette LT4 |
I am a Referee of life.
Go to the FAQ's and search.Krue has a good index.There is a very good post on cleaning lubing and adjusting the 3 speed column shifter.I would try that before i threw down the $$ for a floor shift.I have cleaned and adjusted mine and no longer have the problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jul 2004
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#6 | |
Step Brother
Gone to greener pastures
![]() Join Date: May 2007
Check the bushings.
There should be some where the 1st/Rev, & the 2nd/3rd linkage attaches to the shift arms on the tranny; & if memory serves, where the shift linkage exits the steering column.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
