performance upgrades?
Hi i finished getting my truck running and i want to get some more horse power out of that 350. I was just wondering what the best under the hood upgrade to get for the money would be.
Stephen |
the boat guy
Re: performance upgrades?
so whats done to your 350, what kind of carb, intake, exhaust, cam, heads, pistons, compression ratio, what kind of transmission is behind it, rear end gear ratio, how will you be using it, towing/drag/makin tire fires?
K&N air filter, platinum spark plugs, tornado, octain booster, NOS floormats and steering wheel cover
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, Last edited by brad_man_72; 03-13-2008 at 04:21 AM. Reason: couldnt resist being a smartass |
everything is stock its the stock 4 barrel carb. sorry i don't know the gear ratio. but i just want more power for smoke shows and a little street racing
Stephen |
the boat guy
edelbrock performer rpm intake, cam, and headers.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
I'd put headers/duals at the top of the list, that'll give you a good starting point and of course to me the sound of it is always the most enjoyable mod.
supercharger
ΜΟΛΩΝ ΛΑΒΕ |
thanks guys. ya i think im gonna get the intake manifold and cam and lifters suggested and the guy at the muffler shop in town says he can make me custom dual exhaust exiting just in front of the tires for 400 bucks
Stephen |
The Edelbrock Performer is a good choice - the RPM is made to turn higher RPM at some sacrifice to the bottom end; wrong choice for a daily driver IMHO.
400 is pretty high for a simple truck setup before the wheels. Do be sure to get headers though, especially when getting a cam. The factory manifolds flow terribly.
Side note, when did the Canadian dollar become higher in value than the USD? I remember when it was worth about 60% of the equivalent USD amount. Was thinking it was higher because of the Canadian price but then I looked at the current exchange rate. |
i would say headers, and a good cam and intake are the most important thing... but really it all works together so make sure you do your homework before picking out parts
#11 | |
Sierra Grande Club
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#12 | |
Sierra Grande Club
![]() s/t
#13 |
k so the edelbrock performance RPM is for higher end power, and the permance one is for lower end, cuz im more interested in the lower end for just flippin laps around town
Stephen |
#14 |
and ya the canadian dollar has been about the same for all of 2008 so far it was higher than the USD for a while
Stephen |
#15 | |
The RPM has a taller plenum and a more straight run to the port from the plenum - this gives better top-end at some expense of mixture velocity at the low end. It's not a HUGE difference, but if you're building to 1HP/CID or less it's noticeable. |
#16 |
well seen as how its that little of difference on the bottom end i'll probably just end up choosing whichever is cheapest. for the exhaust what kind of headers should i get? what kind of mufflers I was thinking flowmaster super 40s and how much money should I expect for all of it bought and installed? thanks guys i really appreciate this if i'm gonna spend my money i might as well do it right the first time.
Stephen |
#17 | |
![]() ![]() ![]() But, I also went with the non-RPM performer. Last edited by Jim_PA; 03-13-2008 at 07:31 PM. |
#18 |
before wasting any money i'd check to see if the motor will take the additional power without self destructing//cam intake and exhaust arent going to help much if you've got worn out heads and rotating assembly
#19 |
#20 | |
#21 |
![]() Join Date: Dec 2006
I scanned through this thread. The complaint is "low power".
The solution to low power is not to add a trick intake,unless you run a parts counter. First you do a complete TUNE-UP . I would recommend that you get a service manual (even a Haynes is better than nothing) and carefully check/fix everything listed under tune-up. A motor that is not running smoothly,with improper ignition timing,,incorrect fuel/air mixture,vacuum leaks,wrong spark plug gap,bad wires,old pittted points with dwell out of spec ETC just may seem to need a $200 manifold but really you should check all the above and more before even thinking about performance mods.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#22 |
There's the catch of the week - I sure didn't read the original post as carefully as I should have. This is outstanding advice, and I've worked on MANY vehicles where a Saturday spent in the driveway tuning has made an order of magnitude difference in the vehicle.
I'm a little ashamed I missed it :/ Nice one ![]() |
#23 |
the boat guy
he said that he just got it running, and we all assumed he meant running correctly.
if youre running a th400 the stock tq converter has a 800 stall, a higher stall would liven the truck up quite a bit
#24 |
First and foremost, what is the head casting number. Without consideration to head flow, valve size, and combustion chamber size, it is hard to go from there without stabbing in the dark. Good heads (if not Vortecs dollar for dollar are the best $$$ spent) then cam, then intake and carb and headers. One without the other is a waste of $$.
#25 |
I think i have the truck running very good, i got it running myself and then took it to my mechanic and he put a lot of work in it. i also put in electric ignition which i forgot to mention earlier. I overheated it one time trying to top it out but towed it to the shop and they checked for damage and there was none. So as far as the engine being able to handle performance parts as far as i know i think its fine. As far as new heads go how much money does that cost to get installed by a mechanic since I have no mechanical experience being only 17 i'm not sure if I could do it myself
Stephen |
