Old 03-13-2008, 05:47 AM   #1
Ace in the hole
front door pillar support - re-enforcement
I am working on the rust on my cab, I bought the front door pillar support like the one pictured. My question is that there is a support re enforcement piece that bolts in behind the brace, where can I get them? or do I have to custom make them?
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 03-13-2008, 07:05 AM   #2
3intheTree
Re: front door pillar support - re-enforcement
I think the front fender bolts into that hole there, if that's any help
3intheTree is offline   Reply With Quote
Old 03-13-2008, 07:14 AM   #3
3intheTree
Try this thread, he's replacing his pillars as we speak.
http://67-72chevytrucks.com/vboard/s...d.php?t=282857
Old 03-13-2008, 07:18 AM   #4
Ace in the hole
you are correct, the fender bolt goes thru the large hole and also goes thru a thick re enforcement piece. that re enforcement piece also gets bolted in with the two bolt holes that go thru the rocker backer. The re enforcement piece is the one I am looking for.
Old 03-13-2008, 07:27 AM   #5
Richard H.
Spanked once
Richard H.'s Avatar
I made mine out of 12 ga;and 2" in freeze plugs and they are very worth the trouble . Really strengthens the support and the fender mount.
Richard H. is offline   Reply With Quote
Old 03-13-2008, 07:32 AM   #6
Ace in the hole
thanks, I was looking at the piece that was rusted into the pillar section I cut out and was thinking along the same lines. It would not be to hard to fabricate one with a chunk of steel and some washers.
Old 03-13-2008, 07:35 AM   #7
Green Machine
Green Machine's Avatar
Here's a link to an old post of mine with pics, might be able to score some from a junk cab. I was missing one, got missed on the assembly line I think.
http://67-72chevytrucks.com/vboard/s...d.php?t=179996
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-13-2008, 07:56 AM   #8
Richard H.
Spanked once
Richard H.'s Avatar
Like so...
