Old 03-13-2008, 06:41 AM   #1
Rust Buster
Rust Buster's Avatar
67-68 GMC Radiator/Core Support
I'm hoping someone here can point me in the right direction because I can't seem to find anything through the search feature.
I need to convert a 67-68 Chevy core support to a GMC one. Has this been the topic of any threads?
I assume it's just a matter of welding on the headlight brackets?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 03-13-2008, 06:45 AM   #2
uncle
Re: 67-68 GMC Radiator/Core Support
That's pretty much it. You will also need the hood latch assembly.
uncle is offline   Reply With Quote
Old 03-13-2008, 06:48 AM   #3
Rust Buster
Thanks for the quick response. Do you just us the grill to line up where you would weld it on?
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-13-2008, 11:53 AM   #4
GMCPaul
I make a cardboard or posterboard templet around the headlight brackets spot welded to the GMC radiator support, then I move the templet to the Chevy core support and drill out the spot welds on the Headlight brackets holding it to the GMC core support and then when I go to install it on the Chevy the template allows me to install it exactly as it was on the GMC, it better over measuring, re-measuring, measuring again, and then finding after done I'm slightly off a little in one direction. Far easier to be precise using the template.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 03-16-2008, 04:57 AM   #5
38chevyhotrod
38chevyhotrod's Avatar
GMCPaul
I am sorry to bump in on this but could gmc paul please respond to mails i have sent on an order???? otherwise i have to cancel for sure.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 03-17-2008, 11:24 PM   #6
GMCPaul
I went into emails to investigate this and found the reason that your emails had not been responded to and the fact is you sent the first one at 12:14am Saturday March 15th our time in Indiana, we closed on Friday March14th at 5pm and we reopen Monday March 17th at 9am so no one has seen youir emails till I just looked.
Your order has shipped and everything will arrive before March 23rd as you requested, tomorrow morning after we open we will also contact you.
GMCPaul
Old 03-18-2008, 12:09 AM   #7
drivethechevy
drivethechevy's Avatar
wouldnt u be better off finding an original gmc core support and repairing that one if u have to rather then drilling weding nd measuring to make the chevy a gmc, thats the route i woud take before i thought about changing chevy core support
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 03-18-2008, 12:16 AM   #8
Rust Buster
I'd love to take that route, but 67-68 GMC core supports are not readily available...
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-18-2008, 02:50 AM   #9
Ben IV
I did this mod too, I just took measurements and swaped them over. Btw gmc core supports were the same from 67-72. Still hard to come across originals though.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 03-18-2008, 03:43 AM   #10
bhoeger70
bhoeger70's Avatar
If you can wait I might have a 67 GMC core support for you in about a month.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 03-18-2008, 05:30 AM   #11
Frizzle Fry
Frizzle Fry's Avatar
Aren't all 67-72 GMC core supports the same?
Frizzle Fry is offline   Reply With Quote
Old 03-18-2008, 08:01 AM   #12
Rust Buster
Now we're getting somewhere!! I was able to get a 72 GMC core support. Now, are you telling me that this will be the same as a 67 and will fit the 67 GMC front clip and grill just fine?
If so, you all made my month.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-18-2008, 10:12 PM   #13
drivethechevy
yup the 72 core support will work with the 67 front clip i have a 72 core on my 68 gmc and it bolted up no problems its alot easier to just use an original then modify a chevy to fit even if an original is hard to come by
good luck
