Old 03-13-2008, 07:35 AM   #1
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Running pipes through cross member ?
I just got my Sanderson 3/4 length headers from ECE.( pics coming soon) I'm going to run the pipes through the rear cross member. what is the best way to cut the holes in the cross member at home without a torch or plasma cutter. I like doing as much work as i can on my truck. If it can't be done I'll see if the muffler shop will do it..
John
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 03-13-2008, 07:46 AM   #2
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Re: Running pipes through cross member ?
I think anything you could use at home that WASN'T a torch or plasma cutter would take forever and not be worth the trouble. I'd climb under there, measure out and draw with chalk where you want the holes, go down to a muffler shop and have them fire up the oxyacetylene torch and go to town. Shouldn't cost you more than $20 and you'll be done in 15 minutes. 5 to put it on the lift, 5 to do the cuts, 5 to take it off the lift and pay them.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 03-13-2008, 07:47 AM   #3
custom72c20
custom72c20's Avatar
Plasma cutter will leave a cleaner cut which makes for less grinding.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 03-13-2008, 07:58 AM   #4
caja_larga
hole saw.
caja_larga is offline   Reply With Quote
Old 03-13-2008, 08:40 AM   #5
WHYBYNU
WHYBYNU's Avatar
Thank guys, pretty much what I was thinking. I'm waiting on some snow to melt then headed to the muffler shop. I'm have new pipe run from the headers back with a crossover pipe with 50 series Flowmasters, turn downs right before the rear. Pretty much what I have now just wanting to go through the cross member to tuck it up close to the frame. Thanks for the replies...
JOHN
71 Cheyenne super
ZZ6 - Th350
4/6 drop
Old 03-13-2008, 04:56 PM   #6
jlaird
jlaird's Avatar
I used a hole saw.
jlaird is offline   Reply With Quote
Old 03-13-2008, 06:12 PM   #7
70GMCer
70GMCer's Avatar
found this
http://67-72chevytrucks.com/vboard/s...d.php?t=201474
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-13-2008, 08:42 PM   #8
pat
pat's Avatar
I used a hole saw and almost broke my wrist about 5 times in the hour it took to do it. Id use a plasma if I had one.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 03-13-2008, 09:01 PM   #9
billdo
billdo's Avatar
i was gonna say a hole saww u and the month that it took i would have used a razor blade instead of a hole saw. u need fire to cut that plasma or tourch hole saw.
billdo is offline   Reply With Quote
Old 03-14-2008, 04:21 AM   #10
ANTHONY 67
i have the same headers cut mine with a hole saw didnt take that long but i have a lift
ANTHONY 67 is offline   Reply With Quote
